Rubber Roof On A Deltec? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-26-2013, 05:33 AM   #1
automated tool pro
Rewards Points: 152
rubber roof on a deltec?
any thoughts on seam reduction?
My thoughts were to roll out the rubber 10' x 20' until the curve of the roof cause the rubber to kink and not lay flat. Cut at that point to lay flat and start a new run.
Has anyone ever put on rubber roofing, not strangulated?
do the vent boots and flashing need to be strangulated?
Thoughts on zip_Taping all the decking seams that meet @ the peak. My thought is that it would put less stress on the rubber. Zip-Tape being a brand name and is high density "Pipe tape like" 4" wide it's typically used on homes that do not require home wrap, tyvek. This stuff is tuffer than duct tape and is also rain resistant.
Thanks for any in-put/ and please ask questions.
drywallfinisher is offline   Reply With Quote
Old 08-26-2013, 09:34 AM   #2
Roofmaster
Rewards Points: 2,210
What is a Deltek? Is that like a hyperbolic paraboloid?
Thanks.
Old 08-27-2013, 01:38 PM   #3
automated tool pro
Rewards Points: 152
Thanks.
In the SE US its the name we use for round houses
Old 08-27-2013, 01:53 PM   #4
Roofmaster
Do you mean like a Geodesic dome? What is a "round" house?
Old 08-27-2013, 03:47 PM   #5
Metal Roofing
Rewards Points: 600
http://www.deltechomes.com/
Interesting, i cant say i have ever seen or heard of it until now.
AndyWRS is offline   Reply With Quote
The Following User Says Thank You to AndyWRS For This Useful Post:
drywallfinisher (08-28-2013)
Old 08-27-2013, 04:37 PM   #6
Roofmaster
Thanks Andy. Pretty nice looking homes. There will invariably be a lot of waste re standard roofing materials, but otherwise, I like the look of these. SPF would work well, but not look nearly as good as shakes.
Old 08-27-2013, 10:15 PM   #7
Metal Roofing
Rewards Points: 600
Why the rubber?
If it were me i would use a more attractive roof system. The rubber will sit very flat, and as you mentioned have many seams. The rubber has no style, it is boring imo. I think a unique home like that warrants a unique roof system. I am not even a fan of the comp on that, id do a metal of some sort...SS or metal shingle.
kwikfishron (08-28-2013)
Old 08-28-2013, 07:48 AM   #8
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,760
Why not steel. It is "greener" than rubber.
Old 08-28-2013, 10:10 AM   #9
Rewards Points: 252
Rubber as in EPDM, or Modbit? White EPDM might not look bad, or black modbit run horizontally. Black EPDM would look like a garbage bag.
Either way, i would just cut the membrane at the 'peak' of each section, then run a piece down the seam (much like how the shingles were done in the link above). For the top you could make a cone and cover it with metal as extra protection.
How do you plan on attaching the membrane to the deck?
shazapple is offline   Reply With Quote
The Following User Says Thank You to shazapple For This Useful Post:
Old 08-28-2013, 12:06 PM   #10
Low Slope Roofing
Rewards Points: 114
standing seam or PVC with the standing seam ribs welded on.
Copper would look great on one.
1985gt is offline   Reply With Quote
Old 08-28-2013, 09:02 PM   #11
automated tool pro
Rewards Points: 152
What a pain in the backside. The home is a rental property that was bought up a few years back. In the sell the owners had a bogus roofer come in and do a bang up job. there was lots of water damage and decking that needed to be torn off, 2x8's sistered, and we extended the roof over a covered porch on two sides.
Shazapple__epdm that was pulled off a warehouse, pressure washed...the stuff is jet black even after drying.
LOTS of waste in every way. Deltecs are not green.
Old 08-28-2013, 09:13 PM   #12
automated tool pro
Rewards Points: 152
what about venting at the peak. we drilled holes in every stud ___thats a lot of drilling__to vent from exterior walls to peak.. we're to the point of cutting the sections in the morning, and will be looking to frame up something like this(right) to set on top with louvers instead of doors. THOughts?
we're using a roll on adhesive.
Tags
deltec , roofing
Proper transition between shed roof and shingled roof? aribert Roofing/Siding 9 04-12-2012 03:17 PM
rubber roof Fanatic Roofing/Siding 2 11-10-2011 03:16 PM
Roof leak nightmare..... it won't stop amandat37 Roofing/Siding 52 04-22-2011 12:47 PM
Need opinion on this roof profenx Roofing/Siding 14 10-12-2010 12:56 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
