Rubber Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-14-2009, 11:53 AM   #1
Rubber roof
I have a flat rubber roof that has some minor leaking. I have looked at several different sealants from Henry but none seem to say they are ok for rubber roofing. I have no idea if there are different types of rubber roof material so maybe I just don't understand the labeling. Can anyone tell me what to look for to identify what type of rubber is in place? And then can you suggest some sort of sealant? Thanks!
snyderslake is offline   Reply With Quote
Old 03-14-2009, 03:20 PM   #2
google eternabond.If you know where it is leaking patch with same material,proper primers,glues,edge sealants,etc...
johnk is offline   Reply With Quote
Old 03-14-2009, 04:53 PM   #3
So Eternabond is recommended for a EPDM rubber roof leak/hole?
gofurther is offline   Reply With Quote
Old 03-14-2009, 05:24 PM   #4
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
The Eternabond Co. says it is. Have to scrub the EPDM roof with Weathered EPDM roof cleaner first.
tinner666 is offline   Reply With Quote
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
Rubber Roof and Roof Deck vianak Roofing/Siding 2 10-09-2008 05:37 PM
Rubber Roof Bubbles icma45 Roofing/Siding 2 05-29-2008 01:29 PM
