Rubber Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-09-2011, 09:13 PM   #1
rubber roof
I have a rubber roof and want to use Grace 18" detail membrane around the perimeter as a double protection as I dont really like the look of the 9 "band that is there now. How would I best clean the rubber to promote the best adhesion of this membrane?
Fanatic is offline   Reply With Quote
Old 11-09-2011, 09:45 PM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
I haven't heard of Grace making any 'rubber compatible' product to date. I have seen Grace put on rubber roofs that caused damage and deterioration to the rubber.
tinner666 is offline   Reply With Quote
Old 11-10-2011, 04:16 PM   #3
Rewards Points: 252
I certainly would not start mixing products. A little more research or consultation with a roofer may be in order.
shazapple is offline   Reply With Quote
Pipe insulation: Foam, Rubber, Other? IckesTheSane Plumbing 40 03-21-2016 07:57 PM
Roof leak nightmare..... it won't stop amandat37 Roofing/Siding 52 04-22-2011 01:47 PM
Need opinion on this roof profenx Roofing/Siding 14 10-12-2010 01:56 AM
Laying new roof after removal of old roof rupal Roofing/Siding 9 11-30-2009 05:00 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
