Round Wet Spots On Ceiling - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-09-2011, 09:30 AM   #1
Rewards Points: 29
Round Wet Spots on Ceiling
We've notice in one of our bathrooms upstairs that when it rains, there are a couple of places on the ceiling that cool and very slightly moist to the touch. These "wet spots" are round and about the size of a coffee cup in diameter. I've seen leaking roofs before but I've never seen it be so symmetrical.
Anybody have any idea what could be causing this?
Thanks!
Phreek is offline   Reply With Quote
Old 11-09-2011, 10:07 AM   #2
kwikfishron's Avatar
Rewards Points: 586
Have you looked up in the attic yet?
Post some pictures of the roof above that area.
kwikfishron is online now   Reply With Quote
Old 11-09-2011, 02:45 PM   #3
Gymschu's Avatar
Rewards Points: 836
Not unusual at all. Sometimes a leak is a slow drip that finds its' way thru insulation and plaster/drywall. As it drips ever so slowly the water pools in a symmetrical fashion and as more drips are added to the area, the circular pattern can grow outward. Definitely sounds like a roof leak although I would check to see if there's any condensation coming from a bathroom fan.
Gymschu is online now   Reply With Quote
Old 11-10-2011, 08:39 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,628
Get in the attic as the other pros said. Where the leak shows itself is by no means where it might be coming from.
Old 11-10-2011, 11:18 AM   #5
Chicago, IL
Michael Thomas's Avatar
Also, consider causes other than a "roof leak", especially as the "leak" is evidencing itself in multiple locations.
Here's one I saw recently where several previous attempts to locate the source of the leak had failed.
In this case the watermarks on the ceiling were caused by condensation in a bathroom exhaust line in the attic above - the "clue" here, even before entering the attic, is the stain beside the bathroom exhaust fan housing and the linear nature of the water damage adjacent to the fan.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
The Following User Says Thank You to Michael Thomas For This Useful Post:
Windows on Wash (11-10-2011)
Old 11-10-2011, 08:03 PM   #6
Good advice.
Drywall spots does not mean the roof is leaking by any stretch.
I have tracked back leaks that were related to central vacuum condensation as well as exhaust fan issues.
Poke you head up the attic and start from there.
SW Brilliance Ceiling Paint - Seeing Roller marks bentleyvt Painting 50 03-22-2012 11:33 AM
covering water spots on the bathroom ceiling mark.coleman Painting 5 08-28-2011 08:15 AM
What to do with this old ceiling? mudworm Building & Construction 4 07-17-2011 04:54 PM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 06:32 PM
ceiling stains ellie09 General DIY Discussions 1 06-18-2009 05:54 AM
