12-09-2011, 01:27 AM
#1
Rotting Fascia Boards
Hi.
I just bought a house and have started scraping away peeling paint to get it ready to repaint....of course I come across paint covering rotted areas of the fascias. I know they should probably be replaced, but the problem is that the house has a very low-pitch roof (nearly flat) which is the foam built-up type roof, and the built-up foam is flush with the top of the flashing--if I made any sense--...removing the damaged fascias seems relatively simple, but attaching new ones not so much, and the flashing seems to cause any water to run directly onto the wood...should the flashing be pried away a little to prevent that? I've added a few pics to get the idea.....thanks for any input!
Josh
12-09-2011, 07:05 AM
#2
Residential Roofer
Wouldn't want to comment with out that pic.
God Family Country Work Play
12-11-2011, 03:45 PM
#3
Here are a few photos.
12-11-2011, 06:59 PM
#4
The nails need to be removed that are in that metal roofing (or what ever it is) The wood needs to come off and be replaced then just have a siding company install PVC coated aluminum coil stock then reinstall the nails in the over hanging metal. No more rot or painting ever again.
12-11-2011, 07:11 PM
#5
PVC shrinks and fades, and so does aluminum.
Get good steel that is not PVC coated or simply painted.
http://emcobuildingproducts.com/
12-11-2011, 07:20 PM
#6
Not sure who this other poster is but I can say 100% he has no clue. PVC coil stock does not faid, if installed with oval shaped holes punched with a special punch made just for this it's also not going to buckle. Good luck trying to even trying to find any form of steel to cover this, and even if you did it would rust in time.
I've worked on hundreds of older homes and everone I've seen with galvinized drip cap, it's rusted.
12-11-2011, 07:38 PM
#7
Take a look at the link.
That steel is galvanized and coated with teflon.
If you think PVC doesn't fade, you must have just started yesterday. Aluminum is for soffits, not for coil, roof edge, or fascia's anymore.
Just sayin' there are better products to use than what the guy with the aluminum brake always uses....and at affordable pricing. (compared to copper, etc)
12-11-2011, 07:54 PM
#8
I've been doing siding for over 30 years. Not one piece of PVC coated coil stock I've ever installed has faided. Just plan painted coil stock fades.
12-11-2011, 09:11 PM
#9
I'm not sure that PVC coated aluminum has been out that long but, ok.
You must only install white then?
I agree that the plain painted fades more, but it's a fact that PVC fades over time, especially colors. Look it up if you don't want to believe me.
It's also a fact that steel is a better product to use over aluminum for fascia's and siding.
I am not a DIYer either. Our business has been around for 3 generations and I personally have been doing this work for 16 years in the field.
I have PVC coated steel siding on my own home, along with PVC coated aluminum for the coil and painted steel fascia's. In only a few years I can already see the PVC fading and I'm in MN. I see now that the siding I used (Edco, not Emco) also offers teflon coating on their steel. Wish they would have had that a few years ago. I knew steel was better for numerous reasons and didn't fade or chalk like most vinyl's, but it's still PVC coated. It's not going to stay fade free or chalk free for as long as I would have liked.
Aside from that, PVC also cracks, shrinks, scratches easily.
12-11-2011, 09:26 PM
#10
PVC coated aluminim coil stock has been around for at least 20 years that I know of.
Older aluminum siding caulked, as well as old vinyl siding. That's over and done with. the new stuff does not do that.
12-12-2011, 08:39 AM
#11
Oh really?
You sound like a sales rep. Sure, it has improved, but it is still vinyl and it is still aluminum.
I have seen vinyl and aluminum, fade and chalk within 5 years. Ask an insurance adjuster if vinyl or aluminum fades or chalks.
12-12-2011, 08:48 AM
#12
Exterior Construction
Still happens and especially in the case of new construction type quality stuff.
12-12-2011, 12:39 PM
#13
Low Slope Roofing
The problem with the water running over the rake edges is because the foam roof has been built up over the gravel stop. Originally the roof is more then likely a Asphalt and gravel roof. There should be a gravel stop all the way around one the Eve edges (gutter edge) I would have typically been 3/4 of an inch higher then the roof. 1" or so on the rake edges. Now that they spray foamed it can run off anywhere. The water will keep going where it wants to, Remove the fascia boards, prime them and replace. Then have someone wrap them with STEEL. Steel will last 10X longer then the thin alum the siders use. Any roofing company worth there salt can make a simple fascia cover in 24 ga.
We just did a fascia wrap on house just like this about a month ago. Granted we do not do it much but it was no problem for our guys to been a simple J style piece and wrap the fascia. 24ga Prefinished white on that job. Granted it wont be a few hundred bucks like it would be with PVC. Oh also to point out not one face nail was used.
Note we were talking about fascia wrap not drip cap what ever that is. Drip edge or cap metal its one or the other...
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
