Rotted Decking, Soffit, And Fascia - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-20-2011, 08:45 PM   #1
Rotted decking, soffit, and fascia
Hi, I've learned so much from these forums but it's the first time I've posted. Thanks in advance for any help!
I need to repair some roof rot caused by a poorly mounted over-the-garage basketball hoop. the previous owner nailed through the shingles and didn't seal the holes. Parts of the decking, fascia, and soffit are rotted. I already removed the soffit, fascia, and the board behind the fascia. See pics.
My questions:
1. Can I mend the decking or should I replace the entire plank of decking? there's only a 1' x 6' section that looks rotted.
2. Do you think I need to replace or reinforce the rafters and lookouts? There seems to be a little rot at the ends.
3. Finally, is this something I should do myself, or call a professional? I would consider myself not quite a beginner DIYer, but not yet an intermediate either.
Again, thanks!
Nano
nanotech1112 is offline   Reply With Quote
Question about replacing fascia and soffit paneling creamaster Carpentry 2 03-31-2010 10:01 PM
Vinyl soffit and fascia msyv Building & Construction 7 09-13-2009 11:21 PM
Help with installing aluminum soffit and fascia Boontucky Roofing/Siding 3 09-01-2009 08:47 PM
Rotted Soffit and Fascia boyfly Carpentry 1 05-08-2009 11:12 PM
How to replace a partially rotted soffit that's sandwiched in pgraff99 Carpentry 21 10-22-2008 03:25 PM
