Room Leaking From Chimney Somewhere Help Please - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-10-2013, 07:00 PM   #1
Room Leaking from chimney somewhere help please
I have leak coming down into my basement and I believe it has something to do with either the chimney chase cover or the area area where the chimney meets the house. Any help would be greatly appreciated.
Room Leaking from chimney somewhere help please-20130310_144942.jpg   Room Leaking from chimney somewhere help please-20130310_145001.jpg   Room Leaking from chimney somewhere help please-20130310_145302.jpg
sicnic is offline   Reply With Quote
Old 03-10-2013, 07:51 PM   #2
Rewards Points: 13,694
First thing I see is the cap was not made big enough.
Looks like water can get in under the J moulding and outside corner.
Really need to get up on the roof to look at the whole cap and flashing set up.
tinner666 (03-10-2013)
Old 03-10-2013, 08:59 PM   #3
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Looks like Joe nailed it. Probably not wrapped with WRB either.
tinner666 is offline   Reply With Quote
Old 03-10-2013, 09:25 PM   #4
WRB?
House wrap?
Old 03-11-2013, 06:11 AM   #5
Pro Slate Roofer
tinner666's Avatar
Originally Posted by joecaption View Post
WRB?
House wrap?
Water Resistent Barrier. Since chimneys are often not considered a part of the building envelope, I often see the plywood is the only thing behind the siding. No wrap at all.
Isolated Room in Basement - Theater Room EricWindow HVAC 8 11-24-2012 03:19 PM
help with leaking chimney dartman92 Concrete, Stone & Masonry 3 03-06-2012 04:11 PM
Well Room (Cold Room) Issue--Advice Needed TomPgh Building & Construction 11 01-03-2011 06:31 PM
Leaking water into under-garage storage room phauck Building & Construction 5 01-01-2011 06:39 AM
hello , i have a leaking balcony over a room amanda everson General DIY Discussions 3 10-03-2009 09:48 PM
