Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing/Siding
Old 05-07-2006, 07:58 PM   #1
rooled roofing
i am looking to replace my old roof on a back porch which is shigled right now but the roof is nearly flat. so i was going to put down rooled roofing or torch down roofing which type does anyone suggest. and also can i put either of them down ontop of the shingles or do i have to tear them off. please thatnk you for any help anyone can give me:confused:
chefjb98 is offline   Reply With Quote
Old 05-08-2006, 04:07 AM   #2
PRO
Glasshousebltr's Avatar
rooled roofing
Chef, rolled roofing bites, don't even consider that.
Torch down will work if you can do it right while keeping your house from going ablaze.
Go to a roofing suplier and ask to see the cold application rubber. It's pretty simple to apply.
Hope this helps.
Bob
glasshousebuilder.com
Glasshousebltr is offline   Reply With Quote
Old 05-08-2006, 04:54 PM   #3
rooled roofing
thank you for the info i will check it out once again thank you
Lathe metal roofing? Stan ETenn Roofing/Siding 19 06-18-2013 07:48 PM
Choosing The "Right" Roofing Contractor, How To Evaluate Who Is Right! Ed the Roofer Roofing/Siding 27 04-25-2013 06:10 AM
Roll Roofing Repair IfItAintBrokeFixItAnyway Roofing/Siding 9 09-13-2009 06:32 PM
SPF Foam Roofing on Gables? WhyMeWhyNow Roofing/Siding 3 07-25-2005 06:31 PM
What roofing material is right for me? Grumpy Roofing/Siding 0 07-07-2004 08:41 PM
