rooled roofing
i am looking to replace my old roof on a back porch which is shigled right now but the roof is nearly flat. so i was going to put down rooled roofing or torch down roofing which type does anyone suggest. and also can i put either of them down ontop of the shingles or do i have to tear them off. please thatnk you for any help anyone can give me:confused:
Chef, rolled roofing bites, don't even consider that.
Torch down will work if you can do it right while keeping your house from going ablaze. Go to a roofing suplier and ask to see the cold application rubber. It's pretty simple to apply. Hope this helps. Bob |
thank you for the info i will check it out once again thank you
| All times are GMT -4. The time now is 03:58 PM. |
