Rooftop Skylight Curb Rehab - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-22-2013, 07:07 PM   #1
I have a 4' x 8' skylight flat mounted at the top of my hip roof (it is the "peak" or ridge of the roof. It appears to be curb-mounted on 2x lumber, and the weather has taken a toll on the curb. I haven't found any rot, but the cracks in the wood are widening. I'm re-roofing right now and would like to rehab the curb. My initial thought was to sand it down, apply an elastomeric paint primer, followed by the finish color. I'm looking for suggestions to help better preserve the curb going forward. I DO NOT want to pull the skylight off at this time. Mahalo,
Jason
jkauai is offline   Reply With Quote
Old 10-22-2013, 11:08 PM   #2
Rewards Points: 14,312
I can not remember the last time I saw bare wood showing on a curb.
Wrapped it in aluminum coil stock flashing is the norm.
Old 10-22-2013, 11:49 PM   #3
Yeah, that's a good example of the quality of this house. I think I'm going to clad over it with copper, overlapping the existing flashing underneath. Don't know why I didn't think of that earlier.
Old 10-24-2013, 01:00 PM   #4
Roofmaster
Rewards Points: 2,210
Got any pictures of this beast? This should be interesting.
Old 10-24-2013, 02:52 PM   #5
Yeah, I'll take some and post later today. I thought it was odd to have a wood curb exposed to the elements, but it's the first house I've had or worked on with a flat skylight.
Old 10-24-2013, 07:42 PM   #6
Roofmaster
4 x 8 foot, flat is pretty big, Does it snow where you live?
Old 11-25-2013, 10:29 AM   #7
Do you know the manufacturer of the skylight? Velux makes step flashing kits for all of their curb mount skylights. You can see an example of the kits available on the market here: http://www.skylightsforless.com/store/p/40-Step-Flashing.aspx#.UpN5z-LjVik
Most of the sizes are standard so you may be able to use one of their kits regardless of the skylight manufacturer. The aluminum kit may save you a few dollars in comparison to DIY copper flashing.
usbp.josh is offline   Reply With Quote
Replacing a curb mounted skylight. Red Robin Windows and Doors 2 07-25-2013 07:50 PM
installing new skylight w/curb on top of old and bigger curb amakarevic Roofing/Siding 47 06-16-2012 07:52 PM
Skylight Install: How to Retrofit New Asphalt Paper? amakarevic Roofing/Siding 11 06-06-2012 02:01 PM
Velux skylight curb -- PT lumber or regular? amakarevic Roofing/Siding 3 05-30-2012 04:22 PM
Damaged Shower Curb ohiogirl1965 Plumbing 0 06-29-2010 02:56 PM
