Roofing\venting Proposals = Confused Homeowner - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-10-2012, 07:55 AM   #16
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,720
You can install soffit vents in this case and open up the overhang pretty simply.
Old 11-10-2012, 05:47 PM   #17
Registered User
Rewards Points: 5,180
Your gable-end vents are too low for exhaust, they may be acting as intakes now. Solar-powered payback time: depends on existing insulation levels; http://epics.ecn.purdue.edu/hfh/_tea...larresults.htm
http://www.fsec.ucf.edu/en/publicati...SEC-GP-171-00/
Is there a radiant barrier?
Gary
Old 11-11-2012, 07:40 PM   #18
I would go with several solar powered fans since you will have no shortage of solar power in AZ. close of the gable vents. Install plenty of eave ventillation since it looks like you have large overhangs.This will draw the air up from the lowest point and out the highest point.
beerdog is offline   Reply With Quote
Old 11-12-2012, 03:10 PM   #19
Hi all,
I am following some threads on vents & fan installations. i have a concrete tile roof & it primarily has 'soffit' for intake (I see continuous ventilation holes around the roof). There are 4 or 5 domer style vents near top portions of the roof. I have been thinking about adding fans just below the domer vents so that it can push air out? Installation will be very easy since I just have to get fans & install just below the domer vents (i don't plan to open the roof or anything - just use the existing vent openings). Will it help? I live in Northern California - we get a few really hot days & a few really cold days. I am wondering if adding couple of attic fans (either solar or electric powered with thermostat) will be a good idea?
Appreciate your thoughts/input.
Thanks,
-venvis
venvis is offline   Reply With Quote
Can a homeowner perform electrical work in MA? dpd512 Electrical 77 04-11-2012 07:48 AM
Confused about Sub Panel stqevo Electrical 28 10-02-2009 12:04 AM
New, Confused Homeowner LoneRanger Building & Construction 1 09-11-2009 07:30 AM
Alaskan homeowner working on home Thurman General DIY Discussions 10 08-15-2009 01:51 AM
Trying to wire my bathroom... confused... Alan Electrical 3 11-23-2008 05:44 PM
