Roofing And Venting Priorities - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-22-2013, 12:11 PM   #1
Solutions (handyman)
Rewards Points: 362
Roofing and venting priorities
Is it best to have all venting, chimney and stacks in place before installing a metal roof or does it matter? My thought is that everything should be in place before roofing but I'm open to suggestions. Thanks
Mark Harvey is offline   Reply With Quote
Old 04-22-2013, 12:23 PM   #2
Roofmaster
Rewards Points: 2,172
Assuming you mean a standing seam metal roof, and if you are talking about a masonry chimney, yes the masonry chimney should be in place. I would wait on plumbing stacks, so you can bring them up through the center of a panel so they don't fall on a rib. Allowance for panel movement must be provided around both stacks and chimney. The base flashing attached only to the roof, and the counter flashing attached only to the chimney.
The Following User Says Thank You to jagans For This Useful Post:
Mark Harvey (04-22-2013)
Old 04-24-2013, 11:14 AM   #3
Rewards Points: 252
I agree with Jagans, the vent stacks are pretty easy to install after. Although, if you are strapping the roof it is nice to have everything in place so you can install strapping around the vents as well.
shazapple is offline   Reply With Quote
Old 04-24-2013, 12:33 PM   #4
Roofmaster
Hey Shaz, what do you mean by strapping? We use the term strapping with running roll goods parallel to the slope, what is the meaning with metal roofing? Just wondered, as terms seem to differ in different locales.
Thanx
Old 04-24-2013, 01:24 PM   #5
Rewards Points: 252
Sorry for being vague. When I talk about metal roofing I'm referring to corrugated panels, which is by far the majority of metal roofs put on in my area. In some situations corrugated panels are installed directly to the deck, but in some new construction and (ideally) all replacements 1"x4" strapping is installed perpendicular to the slope. This creates a gap between the deck and metal roofing, so if you don't have strapping around your vent pipes it makes it difficult to fasten the flexible rubber boot.
Old 04-24-2013, 09:59 PM   #6
Roofmaster
Just to be clear, these are corrugated roofs with exposed fasteners?
Thank You.
Old 04-24-2013, 11:19 PM   #7
Rewards Points: 362
Roof
Yes, typical metal roof with 36" width, ribbing not sure of guage.
Choosing The "Right" Roofing Contractor, How To Evaluate Who Is Right! Ed the Roofer Roofing/Siding 27 04-25-2013 06:10 AM
Plumbing, ducting, venting, roofing, who's job is whose? daluu Building & Construction 13 11-08-2012 12:44 PM
Attic venting options Bob_T Roofing/Siding 5 06-20-2009 06:54 PM
Soffit venting vs. DCI Smart Vent JDPII Roofing/Siding 1 02-28-2009 09:42 PM
Roofing Proposal: Can vs Ridgevent casey_wa Roofing/Siding 9 05-12-2006 03:02 AM
