Roofing Valleys - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-14-2012, 11:43 PM   #16
@ tinner - I just caught you were referring to the buckling in the old copper with the picture. That has nothing to do with the nailing and certainly didn't cause any leaks. That was the fault of the way they were installed. Roofers were sent out with a copper on a coil (which is softer) and valleys formed in the field using foot tongs or even stomping them in. The copper you use is harder and breaks nice and flat. (I am thinking you already know this.)
roofnron is offline   Reply With Quote
Old 12-15-2012, 05:48 AM   #17
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
The warped valley is SS. I've also seen copper, aluminum, and steel valleys warped.
In each case, I was called to fix leaks. In each case, the open valleys had splits and tears from the constant flexing.
In closed valleys, the constant flexing had split the metal and torn the shingles.
Max width of usable valleys should be 14" which will allow nailing within 6-!/2" of center without hitting the metal. When using small slates, the max valley size is 12". That's 12" metal in the copper pix.
tinner666 is offline   Reply With Quote
Old 12-15-2012, 02:31 PM   #18
Roofmaster
Rewards Points: 2,210
Hi Guys,
I suggest that you pick up a copy of "Copper and Common Sense" Published by Revere Copper Co. and read it cover to cover, twice. It was developed and produced in reaction to the significant number of problems that roofers and sheet metal mechanics were having with sheet metal. It is a very well written and illustrated little book, that will help you enormously, and keep you out of trouble.
Old 12-17-2012, 01:16 PM   #19
Roofmaster
Hi Ron,
One of the points I was trying to make with metal, and this is very well documented, is that thicker is not always better. We know that metal moves. Aluminum expands about double what steel does, That is why I spec Kynar coated galvanized steel with return hems, for copings.
If you insist on nailing through your valleys, I would stick with .024" aluminum, not .032". I guess we all have our reasons for doing what we do, but nailing through valley metal causes many of the leaks I find in MD. Maybe where you are you don't get hydraulic pressure too often.
At any rate, Have a Merry Christmas, and stay safe up there.
Choosing The "Right" Roofing Contractor, How To Evaluate Who Is Right! Ed the Roofer Roofing/Siding 27 04-25-2013 05:10 AM
Turn Key Roofing Installation - Single Story, Gable ends, No Valleys darrelllosey Roofing/Siding 8 10-05-2012 06:44 AM
Manufacture History Roofmaster417 Roofing/Siding 6 02-23-2012 02:40 AM
Roofing Material History Roofmaster417 Roofing/Siding 4 09-08-2011 04:49 PM
Roll Roofing Edge Leak toolboxone Roofing/Siding 5 10-07-2009 06:09 AM
