Roofing Underlayment - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-10-2013, 06:06 PM   #31
Rewards Points: 634
That pipe is missing the roof flange.
You have 2 good options, call your hydro company get power shut off and get a proper flange on there.
Order a 2 piece split flange, and have it soldered on site.
I would go with the 2 piece, but I can solder galv.
Your un-good options involve a crap tonne of tar or caulking and will not last, and possibly not work at all.
Regarding the valley, Have you cut the tops of the caps at all? That should help it lay down, if your worried about leaking from the cut, it shouldn't if the valley shingles are installed proper. I would also cut a V out of the shingle course their going under to help it lay down. No matter what you do you will have a slight bump because of all the layers there
PatChap is offline   Reply With Quote
Old 06-10-2013, 06:16 PM   #32
Doing This Way Too Long
Rewards Points: 532
Looks acceptable from that pic.
OldNBroken is offline   Reply With Quote
Old 06-10-2013, 07:08 PM   #33
When i reached the intersecting roof with the ridge cap i cut the top of the ridge cap down the center a little bit so it would lay as flat as it can and put some tar on the split. The only flanges i've found around here are for pipes coming out of the roof somewhere in the center, but not on the edge of a roof, i know of these i've used them before, but never had a pipe on the edge of a roof. Never heard of a two piece flange i'll have to look into that, i pretty much just need half of a flange. Could i take one like they sell at home depot and cut it in half maybe a little more? Previous roofers had nothing around this pipe and the only thing holding it up was the dripedge cut around it (real smart), but now i secured it properly. Also i've never used these type of ridge cap shingles, they are doubled up. I was told thats how they come for architectural shingles.
jpm6621 is offline   Reply With Quote
Old 06-24-2013, 10:54 PM   #34
Completed.
The Following User Says Thank You to jpm6621 For This Useful Post:
Windows on Wash (06-25-2013)
Roofing 15# felt underlayment or Titanium UDL 30 Synthetic Underlayment?? WRAE Roofing/Siding 18 08-26-2014 07:42 AM
Help in deciding the underlayment for roofing homeroofing2 Roofing/Siding 16 12-26-2012 08:09 PM
Manufacture History Roofmaster417 Roofing/Siding 6 02-23-2012 03:40 AM
Roofing Material History Roofmaster417 Roofing/Siding 4 09-08-2011 05:49 PM
Roll Roofing Edge Leak toolboxone Roofing/Siding 5 10-07-2009 07:09 AM
