Roofing And Siding Nailers - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-01-2014, 09:16 AM   #1
bryanp22's Avatar
Rewards Points: 288
Roofing and siding nailers
I will be building a 20x24 garage this summer. How are the siding nailers? It seemed like quite the time saver and especially if it hits perfect depth every time. I also have to reside my house so I'll get a lot of use out of it.
How much time would using a roofing nailer save over just hammering would you say? I am not sure how much time to estimate for shingling to see if a rental makes sense.
bryanp22 is offline   Reply With Quote
Old 04-01-2014, 09:34 AM   #2
roofermann's Avatar
Rewards Points: 399
Unless you are an experienced hand nailer, a roofing gun will be much much faster.
roofermann is offline   Reply With Quote
Old 04-01-2014, 09:46 AM   #3
Rewards Points: 12,878
What type siding are you installing? Vinyl is installed by hand nailing.
A roofing nail gun would be about 50% faster but useless for anything else except roofing.
With one helper I can easily roof a small garage like that in 2, days.
The only hard part is getting them up on the roof.
Order roof top delivery if you can.
Old 04-01-2014, 09:50 AM   #4
bryanp22's Avatar
Rewards Points: 288
So you don't recommend the pneumatic siding nailers with depth adjustment? I am installing vinyl.
Old 04-01-2014, 10:00 AM   #5
It has to be hand nailed unless you want to spend all day having to reset the depth of the nails with a flat bar.
Siding nailers are made for siding like wood or James Hardee, the heads to small for vinyl.
Vinyl is hung on the wall, it can not be nailed tight or it's going to buckle.
As your moving down the wall some areas are going to be harder to nail then others so there's no way to get a consistence depth with a gun.
Old 04-01-2014, 01:52 PM   #6
Low Slope Roofing
Rewards Points: 114
Using a nail gun also decreases your accuracy by 75%. That statement stands for shingles or siding. :D
1985gt is offline   Reply With Quote
Old 04-02-2014, 05:40 PM   #7
Rewards Points: 614
Some siding nailers aren't too bad,but its very simple to hand nail, though I do like staplers for soffit. Roofing guns are great and save a lot of time, can be very accurate in the right hands.
As for time estimate, if its walkable pitch and your doing it yourself with a gun you can probably do around 3 bundles an hour. That would allow for taking some time since your inexperienced. Works out to around a shingle per minute, so no big rush to keep up that pace.
PatChap is online now   Reply With Quote
Roofing or siding first? FlintMich Roofing/Siding 11 05-07-2012 06:59 PM
Is my roofing siding contractor lying? desmoface Roofing/Siding 16 10-09-2011 07:43 AM
metal siding and roofing. leng Building & Construction 3 05-30-2011 12:21 AM
siding a shed before roofing amakarevic Carpentry 5 01-30-2011 09:10 PM
what goes first roofing or siding ME4756@AOL.COM Roofing/Siding 6 09-22-2010 06:03 PM
