Roofing Shingles - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-31-2012, 10:11 AM   #1
Roofing shingles
What is the recommended color for ashphalt shingles on a roof of a house that is subject to four distinct seasons?
Mykal is offline   Reply With Quote
Old 03-31-2012, 10:43 AM   #2
bbo
I'd go with what looks best on the house.
having proper roof ventilation is much more important.
bbo is offline   Reply With Quote
Old 03-31-2012, 01:28 PM   #3
Registered User
Rewards Points: 5,514
Good that you asked, the results may surprise you: http://www.professionalroofing.net/a...2/feature2.asp
Gary
Old 03-31-2012, 02:55 PM   #4
Rewards Points: 252
Gary
Interesting article. I can see how the reflectance of the shingles makes a difference. Other studies have found that the air temperature above a 'reflective roof' is actually higher than a non reflective roof, so I wonder if that would be the case here as well?
It's good to note that the author tossed this in very last in his article
"However, ventilation should be recommended to remove the small quantity of moisture in a roof system; it can prolong the life of a wood deck even if it does not extend the life of shingles. "
shazapple is offline   Reply With Quote
Old 03-31-2012, 05:37 PM   #5
Registered User
A few more you will enjoy: http://www.fsec.ucf.edu/en/publicati...CR-1526-05.pdf
http://www.fpl.fs.fed.us/documnts/fplrp/fplrp543.pdf
Really need wind to help proper ventilation, intake/exhaust alone - struggle:http://digitalcommons.unl.edu/cgi/vi...ventilation%22
Gary
Old 03-31-2012, 07:40 PM   #6
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,628
If you have a vented attic, shingle color has almost zero net impact on temps and efficiency.
Old 04-01-2012, 01:49 PM   #7
Registered User
You should really read the article in my Post #3, at least the conclusions.....
Gary
Re-roofing Architectural Shingles over Architectural Shingles NoDIY4Me Roofing/Siding 11 04-08-2014 07:50 PM
Manufacture History Roofmaster417 Roofing/Siding 6 02-23-2012 02:40 AM
PVC Roofing Shingles JR28 Roofing/Siding 12 09-17-2011 04:54 PM
Roofing Material History Roofmaster417 Roofing/Siding 4 09-08-2011 04:49 PM
Best roofing shingles for the money? gante Roofing/Siding 21 09-08-2011 11:20 AM
