Roofing A Shed - Need Some Opinions - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-23-2010, 04:16 PM   #1
Roofing a shed - Need some opinions
I am building a small shed for my home, roughly 100 sq ft. I will have a 4/12 pitch and am shooting for a 12 inch gable overhang on the sides and front and rear. I live in NE Iowa and get and keep snow for months. A few questions:
1) Do I need venting? My house has ridge vents and soffit vents, I originally planned on matching that.
2) What kind of felt? 15 or 30#? Do I need ice/water barrier?
3) Anyone have any good video/how to guides for roofing? I am pretty handy, but roofing is something I have never done. .. I figured a shed is a good place to learn.
TANC is offline   Reply With Quote
Old 01-23-2010, 04:20 PM   #2
Is this going to be insulated, heated ?
Old 01-23-2010, 04:26 PM   #3
No and No, pretty small shed.
It will bake in the sun almost all day everyday though.
Old 01-23-2010, 05:05 PM   #4
jlhaslip's Avatar
Rewards Points: 1,520
http://www.youtube.com/results?searc...=6&oq=shingles
I wouldn't worry about the ice/water barrier unless you will be heating it.
15# felt or possibly 2 layers would be good.
Venting is good, in case you insulate it at some future point in time.
jlhaslip is online now   Reply With Quote
Old 01-23-2010, 05:08 PM   #5
Rewards Points: 1,494
I would put in soffit vents and also your choice of gable or ridge vents.
For a small shed, gable vents would work just as well as a ridge vent and are easier to install.
Start by putting a drip edge along the bottom edge of the roof.
Next apply the tar paper or felt.
Next put drip edges along the sides.
Then install the shingles.
I suggest measuring for each row of shingles all the way from the bottom edge instead of from the previous row. This avoids having measurement errors get bigger and bigger as you go along.
Old 01-23-2010, 07:37 PM   #6
MJW
I know a guy who built sheds for a living along with ice fishing houses. He never even used felt at all. Myself, I would put something on though. Follow the instructions on the bag. Those will give you enough info to get a shed done.
I&W has nothing to do with heated areas unless it is an older home with substantial heat loss at the top plate. This was because they never had energy trusses in the past.
I would add some venting on the roof just to keep it a little cooler if it sits in the sun.
MJW is offline   Reply With Quote
Old 01-24-2010, 07:46 AM   #7
Interesting about the ice fishing sheds.
Old 01-27-2010, 09:25 AM   #8
jlhaslip's Avatar
I & W shield has everything to do with heated areas.
Code here says it is required to be installed from the outer edge of the roof to a point 24 inches inside the heated exterior wall.
The heated area of the roof will melt snow. The water runs down the roof and freezes at or near the point where the heat stops at the exterior wall.
Repetition allows for ice to build up and dam the next batch of water creating a pool which the I &W protects the roof from being damaged.
If the shed is not being heated or occupied, there is no concern about the ice damming or Ice Shield. No heat, not required.
Old 01-27-2010, 10:48 AM   #9
MJW
If ventilation is correct, then heat has nothing to do with it. Ice dams are created by sun heating the shingles or in instances like I stated above.
The code includes unheated garages also. It used to include sheds until it was amended. Ice dams don't always form from heat loss.
Old 01-29-2010, 11:38 AM   #10
I follow Alan's logic for steps, but if I put I&W does it go on sheeting first? I don't put bottom drip edge on, then I&W right?
Old 01-29-2010, 06:59 PM   #11
jlhaslip's Avatar
bottom drip edge installed first under the I&W shield, then gable end drip edge on top
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
Old 01-29-2010, 07:03 PM   #12
Note I&W sheild sticks to the plywood
Shingles then stick to the I&W shield
Real PIA to take shingles off to reshingle
But that's 20-30 years way.........
Old 01-29-2010, 08:14 PM   #13
MJW
Sometimes yes. It's a real PITA. It mainly is because the roof is too hot when the shingles are installed and/or ventilation isn't working correctly and it boils.
The roofs that are in the shade or face north have very little problems with the shingles sticking. That's why I have come to the conclusion that heat is the problem. Jobs that are done in the heat of summer often have more trouble also.
Arguably, a roof installed in winter is often a better roof than one installed in 90+ degree temps.
If using drip edge and metal soffit & fascia, the edging goes on before the I&W like jlhaslip said. On the rakes it goes on after the felt.
Roll Roofing Edge Leak toolboxone Roofing/Siding 5 10-07-2009 06:09 AM
Roll out roofing on my shed. stevez Roofing/Siding 2 05-14-2009 05:12 AM
Basic shed roofing? Fishy Roofing/Siding 1 09-28-2008 07:02 PM
Rudimentary Shed Roofing Question CGofMP Roofing/Siding 11 03-31-2006 09:24 AM
