Roofing Questions - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-19-2011, 07:59 AM   #1
Rewards Points: 154
roofing questions
going to reroof my garage this summer but have a few questions
for the starter strip do you cut off the tabs? which way do you put the shingle down?
what is proper installation
metal drip edge, ice and water, starter course, shingles?
any other tips i should know?
awdblazer is offline   Reply With Quote
Old 04-19-2011, 09:47 AM   #2
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
When using 3 tabs, cutting off the tabs moves the sealing strip down close to the edge. However, starter shingles/strips are readily available and cheaper than buying regular shingles and cutting them.
ice and water,metal drip edge, starter course, shingles?
seeyou is offline   Reply With Quote
Old 04-19-2011, 10:31 AM   #3
I like to bed the starter strip in roof cement or thru the roof caulking just a habit living in a hurricaine zone but I think it's good anywhere
Don Smith is offline   Reply With Quote
Old 04-19-2011, 10:37 AM   #4
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
I find the regional differences very interesting. I've been roofing for nearly 30 years with another 10 in other construction related fields and the only time I've ever seen any roofing cement used is someplace it should never be used - like smeared all over a slate roof or a chimney. I've never bought any.
Old 04-19-2011, 10:42 AM   #5
All i said was on the starter strip... Ever been in a huricaine trust me it helps
Old 04-19-2011, 11:35 AM   #6
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
I wasn't disparaging the use of roofing cement. I would agree with your use of it. I guess my point was that it's extremely important that everyone puts their location in their profile. What's necessary in one region is sometimes useless in another.
Old 04-19-2011, 03:10 PM   #7
Residential Roofer
Slyfox's Avatar
awdblazer;going to reroof my garage this summer but have a few questions
Yes.
The self sealer strip will be placed to hang over the outer edge of the drip edge and facing up.
ice & water, drip edge, felt, starter course, shingles.
any other tips i should know?[/quote]
Read up on installation specs before you start.
You can go to the manufacturers website and find all the info you need for free.
Pay special attention to fastening & placement patterns.
Good Luck.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Do I need to replace soffit vents?? And other roofing questions. kennykenny Roofing/Siding 5 04-17-2011 09:22 AM
shed roofing questions amakarevic Building & Construction 10 02-09-2011 08:17 AM
Metal roofing questions Axhammer Roofing/Siding 17 08-10-2010 09:10 AM
Questions about floor leveling. SLC or roofing material? Timbro Flooring 3 02-18-2010 07:15 PM
EPDM roofing questions zantar Roofing/Siding 4 05-03-2009 07:10 PM
