Roofing Question! - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-05-2010, 06:28 PM   #1
Roofing Question!
So I just found out my roof has 1/2" sheathing plywood on the roof. The home was built in 1992 and is in Jupiter, Florida. I believe the code is 5/8" for sheathing plywood now. I was all geared up and ready to do a re-roof because I have shingles curling up and had two minor leaks that were patched. All in all it was time for new tarpaper and shingles. All the 1/2" plywood looks good. I have maybe one spot that is slightly rotten that I would replace. What are my options now? Will the Jupiter building inspector now allow me to re-roof over top this 1/2" sheathing? Am I going to have to tear up all this good 1/2" plywood and replace with 5/8"? Before I lay down new felt and shingles????
What are my options, please help!
Cory
BigNiner19 is offline   Reply With Quote
Old 11-05-2010, 06:42 PM   #2
How far apart are the rafters ?
Contact the Building Dept & find out what they require
Old 11-05-2010, 06:44 PM   #3
You pulled a permit to redo your roof? I have never pulled a permit or that before. Most building inspectors wont climb on a roof to check it out.
Everything I state on this forum is an opinion I have developed based on my experience and research as a professional.
wnabcptrNH is offline   Reply With Quote
Old 11-05-2010, 06:50 PM   #4
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Last I heard, Fla. requires the permits AND that all roof and rafter assemblies have hurricane strapping applied as per 20xx code.
tinner666 is offline   Reply With Quote
Old 11-05-2010, 06:54 PM   #5
Yea, Florida you pretty much have to pull a permit in order to touch your house, especially the roof. Its not to bad if you live out in the woods, but if your in a neighborhood near the city you need a permit.
My roof has the rafter assemblies (I'm assuming your talking about the extra 2 X 4's for support on everything). I know that is required and surprisingly, this house has it...but it also has 1/2" plywood sheathing.
Can't get a hold of the building inspector until Monday, I hope they tell me I can go ahead and lay down the felt and shingles over this 1/2" sheathing. Other wise I have a whole other project and more $$$ to spend.
Anyone else with some input or advice or anything at all.
Cory
Old 11-06-2010, 12:10 AM   #6
Rewards Points: 956
no good input but theres good tennis courts in jupiter right
federer is offline   Reply With Quote
Basement vapor barrier question rob7young Remodeling 2 04-13-2008 09:10 AM
I just registered and already have a question Hank22 Roofing/Siding 6 04-08-2008 04:18 PM
Roofing question woodyblab Building & Construction 6 11-06-2006 08:12 PM
Some basic question about roofing help! motd0iyeuem Roofing/Siding 6 12-19-2005 07:15 AM
What roofing material is right for me? Grumpy Roofing/Siding 0 07-07-2004 07:41 PM
