Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 10-25-2011, 07:03 PM   #1
Roofing Question
I am having a new roof installed and a dormer with a window do I need to had a ridge vent installed ?
Shelly T is offline   Reply With Quote
Old 10-25-2011, 07:13 PM   #2
Roofing Question
Do you have any wxisting vents? You should always vent the roof, the way you do it is the only question. Make sure the soffit is vented and air flow is not impeded from soffit to venting
packer_rich is offline   Reply With Quote
Old 10-25-2011, 08:07 PM   #3
Roofing Question
My contractor said the inside temp of roof should be the same as outside temp. so yes.
bobelectric is online now   Reply With Quote
Old 10-25-2011, 10:18 PM   #4
Residential Designer
AndyGump's Avatar
Send a message via Skype™ to AndyGump
Roofing Question
I think that might happen about twice a day for 30 seconds each time.
Andy.
AndyGump is offline   Reply With Quote
Old 10-26-2011, 08:13 AM   #5
Exterior Construction
Windows on Wash's Avatar
Roofing Question
Andy.
Absolutely true.
If you roofer is expecting the inside temp to be the same as the outside, he is living in fantasy land.
Rolled Roofing Leaking and Leaking DIYNewbee Roofing 9 12-13-2009 10:46 PM
Roll Roofing Edge Leak toolboxone Roofing 5 10-07-2009 07:09 AM
Roofing Company Refuses to Quote for ... Dodah Roofing 11 06-03-2009 07:17 PM
Roofing question woodyblab Building & Construction 6 11-06-2006 09:12 PM
Some basic question about roofing help! motd0iyeuem Roofing 6 12-19-2005 08:15 AM
