Roofing Over Existing - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-03-2010, 02:44 PM   #1
roofing over existing
Can you install new insulation and tpo system over existing rubber roof that has 3 inch iso insulation
Roof Dr. is offline   Reply With Quote
Old 09-03-2010, 05:09 PM   #2
Grumpy's Avatar
Rewards Points: 524
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
If code allows, yes.
Cut up the existing rubber before installing the new insulation. Or else you will have a double vapor barrier situation.
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 09-03-2010, 05:23 PM   #3
Doing This Way Too Long
Rewards Points: 532
so glad you mentioned double-vapor barrier in your post Grumps.
We usually just cut out the field membrane and leave the seams just to make sure there are no adverse effects.
OldNBroken is offline   Reply With Quote
Choosing The "Right" Roofing Contractor, How To Evaluate Who Is Right! Ed the Roofer Roofing/Siding 27 04-25-2013 05:10 AM
Metal roofing questions Axhammer Roofing/Siding 17 08-10-2010 09:10 AM
Multiple Roofing issues on my home. *HELP!* 2bsure Roofing/Siding 4 12-16-2009 09:29 PM
Roll Roofing Edge Leak toolboxone Roofing/Siding 5 10-07-2009 06:09 AM
Roll Roofing Repair IfItAintBrokeFixItAnyway Roofing/Siding 9 09-13-2009 05:32 PM
