Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 02-06-2007, 02:25 AM   #1
Question
Roofing and outside temp
Hi All,
I'm having a new roof installed this week (old roof is being stripped off) up here in Massachusetts. The daytime temp on the day in question is supposed to be in the mid 20's and the night time temps in the single digits). The roofer is telling me this is not a problem. Is he correct? I'm having GAF Timberline Ultra shingles installed. Should I be concerned with how cold it is as far as how it will affect proper installation and future potential problems?
Thanks in advance for any advice on this.
-George
GeoNE is offline   Reply With Quote
Old 02-06-2007, 07:50 AM   #2
Is the roofer offering a warranty on any future leaks?
Is this a steep roof?
Is this a low sloped roof?
redline is offline   Reply With Quote
Old 02-06-2007, 08:18 AM   #3
Hi Redline,
Yes, the roofer does guarantee the work. The company has been a local company for a long time. I've also gone and looked at other homes he has roofed in the past. It looks like he does a good job.
As for the slope...here is an overhead view of my house showing the roof angle since I'm not sure how to quantify the slope.
Old 02-06-2007, 09:03 AM   #4
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
Looks like my house. You do not have a low slope roof.
The key concern with doing a roof in the cold is the final seal of the shingles. The shingles have a sealing strip that bonds one shingle to the one above it when it gets warm. Sunlight heats the shingles and causes the seal in time.
The shingles you are getting are a good, heavy, architectural shingle. The weight of the shingle itself will hold them in place pretty well until they heat up enough to seal.
The risk is you will get a very high wind that will damage the shingle before it seals. If you have a warranty against this from the installer then you are fine. Just make sure that you save some extra shingles in case this happens. The likelihood it would is very low in my opinion. So, go ahead and install the roof.
Brik is offline   Reply With Quote
Old 02-06-2007, 09:04 AM   #5
Handyguy
Brik's Avatar
BTW - I'm curious. It looks from the picture to be a newer built home. Why does it need a new roof?
Old 02-06-2007, 09:46 AM   #6
It was built in 1991. I am replacing the original "builder's" roof. The roof shingles are cupping and tearing off. I find pieces of shingles on the ground after wind/rain storms. I heard that there was a bad batch of shingles produced by a major manufacturer around the time my house was built and that maybe I had a bad batch but I never pursued it since I never developed any leaks. I'm sure the builder put on the least expensive shingle he could--(I found out after I bought the house that the IRS was after him for significant $$$) There were no drip edges installed anywhere. I had to get him back to fix leaks around the flashing of the chimney. He even had the bathroom exhaust vents terminate in the attic space instead of directly venting them to the outside.
The roofer I hired is going to install vents thru the roof for the bathroom exhausts. He will install drip edges on all the eves and rakes and put a 6 foot ice/water sheild up from the eves. Roof paper, reflashing, etc...everything that should have been done the first time.
Should I have expected better than 15 years on the original roof? I don't know the grade or make of shingle used originally. I just figured replace it now before it becomes an bigger problem.
Old 02-06-2007, 10:06 AM   #7
Handyguy
Brik's Avatar
Yea, you should have gotten more than 15 years if it was installed properly. Also make sure your attic is properly vented (Ridge and soffit vents) that can also be big contributor to shingle failure.
Old 02-06-2007, 10:57 AM   #8
The ventilation is OK. There is a ridge vent the entire length of the roof over the house. And soffit vents the entire length front and back, as well as 2 large gable vents in each gable. At least that seems to have been designed properly.
Thanks for your advice. I appreciate it.
Old 02-06-2007, 11:29 AM   #9
Commercial Roofing
AaronB's Avatar
I do not like to install asphalt shingles below 30 F because they become brittle when theyre that cold. This increases the risk of breakage/cracking during installation.
Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 02-06-2007, 11:56 AM   #10
Handyguy
Brik's Avatar
Agreed - I suspect the installer has figured that into his price and time estimates. As a DIYer I would do it when its warm because I don't like working in the cold and I do not want to deal with stiff shingles. That doesn't mean though that it cant be done.
Old 02-06-2007, 12:30 PM   #11
Personally, I wouldn't worry too much about it. It's probably not the optimal temp. but if you get a few days of sun, it should be no problem. If he guarantees work and will not charge extra to make any necessary repairs, you should be okay. I know a guy that use to shovel snow off a roof before tearing off and putting back. You should be okay.
cibula11 is offline   Reply With Quote
Old 02-06-2007, 09:10 PM   #12
Tom
Send a message via AIM to tvlfleming
I had architectural shingles installed 2 years ago in November and had no problem. The design of the shingle being 2 and 3 actual layers and not 3 seperate tabs makes it hard for wind to lift them up. As long as their not frozen sitting outside you should be fine. Is it a roof top delivery or are they going to be carried up. Roof top causes less bending of the shingles when their so cold causing cracking.
tvlfleming is offline   Reply With Quote
Old 02-06-2007, 11:32 PM   #13
Commercial Roofing
AaronB's Avatar
I do not worry about them sealing...they will seal. But, because they are so thick AND brittle, we do not do them at those temps. LEaks from cracks in shingles may not materialize for a number of years until the asphalt weathers and opens up at those surface cracks prematurely.
That's just me though.
Old 02-09-2007, 10:27 AM   #14
we always roof all year we are roofers after all. in extreme hot or cold weather there are tricks of the trade to adapt and yes jobs do go slower. Quality is the same as is the warranty. If your job is installed by professionals need not worry.
RooferJim
Massachusetts
www.jbennetteroofing.com
RooferJim is offline   Reply With Quote
Old 02-10-2007, 10:53 PM   #15
OK....The roof went on today instead of Thursday. (The roofer decided it was too cold afterall. Here was the surprise. The original builder had put on a 15 year shingle directly onto the plywood sheathing with no paper underneath at all. No drip edges, no waterproof membrane down near the gutters, nothing. It was 3 tab shingles and nothing else. I guess I'm very luck since I only had to replace one 4x8 plyood panel that had started to delaminate/rot after 16 years. The Timberline Ultra looks great on the house. I'm a happy camper now.
Thanks to everyone who gave me advice here.
