Roofing Nails - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-12-2009, 02:57 PM   #1
Roofing nails
Last roof I did was over 10 years ago and that was by hand nailing. I have recently acquired a nailer to do my roof next month but have no idea as to how many boxes of nails I might need. Roof is a little over 23 squares with approx 200 linear feet of starter shingles. How many boxes will I need?
GerryinBelleRiv is offline   Reply With Quote
Old 08-13-2009, 08:03 PM   #2
Depends on the shingle you are using. With a "standard exposure" (5" to the weather) shingle, such as a 3-in-1, one box will install 20 sq. at 4 nails per shingle.
However, if you elect to use a laminated (shake look) shingle (GAF/ELK Timberline or Certainteed Landmark, those shingles lay 5 5/8" to the weather, and one carton of nails will come pretty close to getting 23 sq installed (at 4 nails per shingle). Two cartons would be the safe bet, but you will have most of that second carton left over.
Hope this helps.
Andy
apkole is offline   Reply With Quote
Old 08-13-2009, 09:34 PM   #3
Typical box count is 7,200 nails per box, with 120 per coil.
That will do abount 21 squares.
Ed
Ed the Roofer is offline   Reply With Quote
Old 08-14-2009, 07:29 AM   #4
Thanks guys, two boxes it is. I guess Habitat can always use the extras.
Old 08-14-2009, 08:44 AM   #5
Rewards Points: 790
I just did my house and it was a little over 30 square. I just barely needed two boxes and had a ton left over. I would buy one box and then get another should you need it along the way. Or buy and two and return it if you don't use it. A lot will depend on how many nails are required per shingle. If you nail 5 in each shingle you'll go through that box a lot quicker.
cibula11 is offline   Reply With Quote
Old 08-14-2009, 05:41 PM   #6
Roofing Contractor
RadiantRoofer's Avatar
Don't forget about how you are going to secure the underlayment. Here in Canada you need that eaves protection. Unless you are just going over your old shingles.
Radiant,
RadiantRoofer is offline   Reply With Quote
Choosing The "Right" Roofing Contractor, How To Evaluate Who Is Right! Ed the Roofer Roofing/Siding 27 04-25-2013 05:10 AM
Source for roofing nails, 3" long, ring shank? buzzymalone Roofing/Siding 7 07-27-2009 10:58 AM
sizing roofing nails rebel Roofing/Siding 15 03-05-2009 03:05 PM
which roofing nails for pressure treated lumber ? amakarevic Building & Construction 11 01-30-2009 03:26 AM
Coiled roofing nails for nail gun twaters12 Roofing/Siding 3 02-06-2006 07:37 PM
