Roofing Nails - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-30-2013, 04:33 PM   #1
Rewards Points: 396
roofing nails
Do any of you use roofing nails with the neoprene washers for installing shingles? Just curious if that would be better than without the washer.
detroittigerfan is offline   Reply With Quote
Old 08-30-2013, 04:49 PM   #2
Rewards Points: 2,238
The problem with using neoprene washers on a shingled roof -
They will hold the layer of shingles, above them, up enough -
so that it will be very evident.
It might also affect the ability of the shingles to seal (Seal-strip adhesion)
Not a good idea!
rossfingal is offline   Reply With Quote
Old 08-30-2013, 04:51 PM   #3
kwikfishron's Avatar
Rewards Points: 196
Nope....and nope again.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
woodworkbykirk (08-30-2013)
Old 08-30-2013, 04:52 PM   #4
Rewards Points: 396
Not a good idea!
What about for vinyl siding?
Old 08-30-2013, 04:55 PM   #5
I can not think of a reason why you would!
The Following User Says Thank You to rossfingal For This Useful Post:
Old 08-30-2013, 05:14 PM   #6
It's always a "best practice" to follow the manufacturer's installation instructions, including fastener type and length recommendations.
RoyalAcresRod is offline   Reply With Quote
The Following User Says Thank You to RoyalAcresRod For This Useful Post:
kwikfishron (08-30-2013)
Old 08-30-2013, 06:28 PM   #7
Rewards Points: 13,300
Both just use regular galvanized 1-1/4 roofing nails.
The nails with washers are for metal roofing, even then I would not use them. Use screws instead.
Old 08-30-2013, 06:33 PM   #8
Rewards Points: 196
I prefer 1-1/2"..........It's a fat finger thing.
Old 08-30-2013, 06:56 PM   #9
I hear ya. I've had to 1" nails a few time, what a but difference, end up holding then with plyers to keep from hitting my fingers.
Never use nails with washer on siding. Vinyl has to expand and contract. Last thing you what is the washers dragging.
What's up with wanting to use nails with washers, get some for free?
Old 08-30-2013, 09:07 PM   #10
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
roofing nails with a metal washer are used for application of torch on roofing`s base sheet, the finish layer is torched down over top of hte base sheet.
plastic top washer nails are used for installing rigid foam and house wrap.. regual siding nails will hold hte foam but dont have as much holding power.. just installing house wrap with staples can easily be blown off with heavy wind.. in some regions plastic top nails are required by code..
as for installing the finished product with washer head nails.. not a chance.. standard roofing nails are all thats needed for roof shingles. if vinyl siding is being installed directly on top of the sheathing that has house wrap on it 1 1/2" nails are all thats needed.. if the walls have rigid foam on them 2 1/2" nails will penetrate the foam, sheathing and into the studs
woodworkbykirk is offline   Reply With Quote
Having problems with roofing nails humberguy Roofing/Siding 9 04-08-2014 10:44 PM
Leak in roof due to satellite. Is this the way to repair it? amodoko Roofing/Siding 8 06-16-2013 03:37 PM
Roll Roofing Advice Needed Quackerjack Roofing/Siding 3 05-20-2013 08:58 PM
Choosing The "Right" Roofing Contractor, How To Evaluate Who Is Right! Ed the Roofer Roofing/Siding 27 04-25-2013 06:10 AM
Roll Roofing Repair IfItAintBrokeFixItAnyway Roofing/Siding 9 09-13-2009 06:32 PM
