Roofing Nail Length... - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-10-2007, 11:24 AM   #1
MLO
Roofing nail length...
I have two layers of 1/2" roof sheathing, making 1" of total sheathing. I will be using a laminated roofing shingle (Malarkey). What is the correct roofing nail length I should use?
MLO is offline   Reply With Quote
Old 11-10-2007, 11:43 AM   #2
Typically, with one layer of plywood deck sheathing, you ar supposed to penetrate all the way through and have a minimum of 1/4" penetration through and past the bottom side of the decking.
With solid plank board decking, a full 1" embeddment into, but without penetrating the plank boards is recommended.
What you have is a hybrid between the 2 recommendations. I would venture to speculate that a full 1" into the double layer 1/2" decking would be suitable, but for sake of leaning to be overly cautious, I would =use 1 1/2" nails minimum.
Ed
Ed the Roofer is offline   Reply With Quote
Old 11-10-2007, 08:50 PM   #3
the roofing god's Avatar
Send a message via MSN to the roofing god
I would be concerned w/expansion/contraction between 2 layers of plywood causing nails to pop out and through the shingles,technically the nail has to imbed 3/8ths of an inch ,but I would be more comfortable w/1 3/4" nails
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Old 11-10-2007, 08:52 PM   #4
when you sheathe over heavy decking 34"t&g.or 5/4" skip sheathing the lower decking doesn`t have the same give as plywood does
Old 11-11-2007, 03:40 PM   #5
Hello,
I have installed many squares of Malarkey shingles. They require a minimum 1/4" penetration through the sheeting, it states that on the bundle wrappers. 1 1/2" should be sufficient. 1" of sheeting,1/4" thickness of two layers of shingles, leaves 1/4" of penetration.
Keith
roofboy is offline   Reply With Quote
Old 11-11-2007, 05:48 PM   #6
GAF READS 3/8THS,AND THE POINT IS W/2 LAYERS OF PLYWOOD THE LOWER WOULD MOVE AGAINST THE UPPER AND CAUSE NAILPOPS UNLESS YOU IMBED INTO THE LOWER LAYER THE REQUIRED AMT,AND EVEN THEN W/DECK MOVEMENT during temperature extremes ,I wouldn`t care for it
Where do I nail Aluminum Fascia? irlizard Roofing/Siding 10 09-07-2016 12:21 PM
Choosing The "Right" Roofing Contractor, How To Evaluate Who Is Right! Ed the Roofer Roofing/Siding 27 04-25-2013 05:10 AM
Roll Roofing Repair IfItAintBrokeFixItAnyway Roofing/Siding 9 09-13-2009 05:32 PM
Roofing nail size scarrell Roofing/Siding 3 03-29-2006 11:52 AM
Coiled roofing nails for nail gun twaters12 Roofing/Siding 3 02-06-2006 07:37 PM
