Roofing Metal On Gable Ends - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-07-2013, 11:03 AM   #1
jayhawk714's Avatar
Rewards Points: 18
Question
Roofing metal on gable ends
Does anyone have pictures of using roofing metal on gable ends?
jayhawk714 is offline   Reply With Quote
Old 05-07-2013, 11:47 AM   #2
Doing This Way Too Long
Rewards Points: 532
What type of roof and why?
...and where the hell is Featherville? Nevermind, found it.
OldNBroken is offline   Reply With Quote
Old 05-07-2013, 12:26 PM   #3
jayhawk714's Avatar
Rewards Points: 18
Gable ends
I have a metal roof which is green in color. Do to how high the gables are we are looking at putting brown roofing metal on them to match the logs of our home. Main reason on metal is because it will be maintenance free and I won't have to hire someone with scaffolding or a cherry picker to paint/oil every couple of years.
Old 05-07-2013, 12:42 PM   #4
Rewards Points: 532
So you are talking a metal fascia, not gable trim for your roof?
If you could post a pic it would help a lot.
If so actually it looks better if it matches the roof, not the walls.
So something like the green sides in this picture?
Old 05-07-2013, 12:58 PM   #5
jayhawk714's Avatar
Rewards Points: 18
There was no picture with your last post. I'm new here so is there something I need to setup to receive pictures?
Attached is a picture of the gable. The metal will be from the top log to the peak.
Old 05-07-2013, 12:59 PM   #6
jayhawk714's Avatar
Rewards Points: 18
Found the picture you sent.
Old 05-07-2013, 01:23 PM   #7
Rewards Points: 532
yeah it never attached the first time.
That is an odd looking structure. So what you want is wall panels. Good idea. I suggest a flush wall panel like the one here. It's a total of 1" stand-out. The key is proper flashings and installation to make it look neat.
You are correct, brown would be more appropriate.
Roofing metal on gable ends-100_0779.jpg   Roofing metal on gable ends-102_0790.jpg
Old 05-07-2013, 01:50 PM   #8
jayhawk714's Avatar
Rewards Points: 18
wall panels
We wanted big covered decks so what we did was install new truss's over the original roof (the old roof was left in place), but we also needed to keep enough slope for the snow to come off. think once we get the gables finished it will all come together.
Thanks for the "wall panel" info. I will have my contractor look into that.
Lathe metal roofing? Stan ETenn Roofing/Siding 19 06-18-2013 06:48 PM
metal roofing repair autx790 Roofing/Siding 3 08-13-2012 06:35 PM
Gable Trim on Metal Roof jm1542 Carpentry 2 11-19-2009 03:58 PM
Metal roofing bronco2 Roofing/Siding 17 08-19-2009 08:22 PM
Cricket Construction on Metal Roofing? Lion Gordon Roofing/Siding 1 07-20-2005 09:59 PM
