Roofing Membrane - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-27-2011, 01:06 AM   #1
Roofing Membrane
how do i install roof membrane
John Lindo is offline   Reply With Quote
Old 06-27-2011, 06:29 AM   #2
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
What kind of membrane on what kind of roof?
seeyou is offline   Reply With Quote
Old 07-06-2011, 11:31 AM   #3
Grumpy's Avatar
Rewards Points: 552
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
John, what type of roof membrane do you want to install? There are numerous flat roofing options including TPO, PVC, EPDM, Modified Bitumen. TPO, PVC, EPDM are considered single ply and are installed either ballasted, fully adhered, or mechanically attached. Modified bitumen is not a single ply, though I have hered it referred to as such on numerous occasion. Modified bitumen requires multiple layers, most often a base sheet and a cap sheet but sometimes a mid ply as well. Modified bitumen can be installed self adhering, cold process applied, or torch applied.
Personally the only DIY roof systems I recommend are self adhering modified bitumen or EPDM. TPO & PVC are my preferred membrane of choice but require specialty tools. I would never dare recommend anyone use a torch that is not properly trained.
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Choosing The "Right" Roofing Contractor, How To Evaluate Who Is Right! Ed the Roofer Roofing/Siding 27 04-25-2013 05:10 AM
EPDM Rubber Membrane Roofing Q's flatlander745 Roofing/Siding 1 04-01-2011 06:44 PM
dex-o-tex roofing membrane 08087 Roofing/Siding 0 03-10-2011 07:34 PM
Metal roofing questions Axhammer Roofing/Siding 17 08-10-2010 09:10 AM
Roll Roofing Edge Leak toolboxone Roofing/Siding 5 10-07-2009 06:09 AM
