Roofing Materials Dilemma?????? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-10-2005, 07:25 PM   #16
A bunch of our local inspectors went to a seminar probably based on Carl's research. I heard the overview but then got busy arguing other, non-building, subjects.<P>
Moisture barriers could be a tricky thing and would probably need to be monitored by the homeowner and homeowners don't like to monitor things. <P>
Mighty Anvil, I've been enjoying your posts. You sound a little different this week.
K2eoj is offline   Reply With Quote
Old 10-11-2005, 10:41 AM   #17
Teetorbilt, Carl only tested asphalt shingles; what are you challenging?
Hammerslammer, I haven't even been on a whole week yet. Will probably run out of information soon.
mighty anvil is offline   Reply With Quote
Old 10-12-2005, 06:39 AM   #18
Commercial Roofing
AaronB's Avatar
So does he only do asphlat shingle technology research?
Was he able to measure the thermal difference between the top and botoom of the shingle surfaces accurately?
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 10-12-2005, 07:19 AM   #19
Carl Cash has studdied all kinds of roofing but his specialty has been asphalt based systems. He did not describe his testing methods in the book.
Old 10-12-2005, 01:11 PM   #20
[/QUOTE]
I ran out of useful information the first day but that didn't stop me. Wife thinks i'm working.
Old 08-12-2007, 01:01 AM   #21
Bump.
Just to bring out some anti-venting information.
Ed
Ed the Roofer is offline   Reply With Quote
Old 08-16-2007, 10:30 PM   #22
the roofing god's Avatar
Send a message via MSN to the roofing god
do the smart thing:Hire rose roofing &sheet metal to do your roof,the man knows his sh*t!,use 50 yr shingles,weather watch is fine for your area,unless you`re moving your house to the adirondacks ,you`ll be fine and vent the soffits and ridge by all means,remember "Rose Roofing and Sheet Metal"
the roofing god is offline   Reply With Quote
Old 08-17-2007, 09:56 AM   #23
And now, a friendly word from our sponsor!
How much did you make on that TRG?
I would recommend Aaron also, but without the payola.
Ed
Old 08-17-2007, 10:50 AM   #24
NOTHING ED ,INSISTING ON TOP QUALITY IS IT`S OWN REWARD!,I did forget you`re a chicagoan also,but I don`t know your company`s name
Old 08-17-2007, 11:47 AM   #25
Right Way Roofing Company
Carpentersville, IL 60110
(800) 726-ROOF (7663)
or local #
(847) 426-9730
Installing all types of roofing systems the Right Way since 1985.
Prior to that, I worked for a large Local # 11 Union Roofing contractor for the previous 8 years doing all types of flat roofing systems.
Ed
By the way TRG, I don't know if you ever got the link to my blog site with some more information.
http://rightwayroofing.wordpress.com/
Here is the opening page headline and categories for you to check out.
This in no way is a solicitation to default to that site for your questions, but I would like to build up some topic streams over there.
Most Commonly Misunderstood Or Under-Appreciated Concepts About Residential Roofing
Posted May 2nd, 2007 by
Categories: What Should Be Included In My Estimate Proposal, References And Testimonials And Previous Jobs List, Tips On How To Select A Roofing Contractor, Proper Sheet Metal Flashings On The Roof Questions, Shingle Roofing Application Questions, Attic Ventilation Questions, Introduction
Old 08-18-2007, 02:26 AM   #26
sounds like we share the same roofing "bible "
Old 08-18-2007, 02:50 AM   #27
I thought I was the only screw-ball contractor still awake and online, but not for any longer.
Just glad that you agree with my roofing and ethics philosophies.
Ed
Old 08-18-2007, 03:52 AM   #28
I fell asleep at 10pm,woke up at 3am,going back to bed
Old 02-19-2008, 08:15 AM   #29
Originally Posted by AaronB View Post
Who says it has to do that to seal aroung the nails?
GAF underlayment has been installed by myself locally for the past seven years, and if that is the benchmark to which all are measured, then I must be lucky cuz I have had ZERO ice dam leaks in theat amount of time.
In most cases a good roof installation is more important than the substrates used.
acorn construction is offline   Reply With Quote
Old 02-19-2008, 12:14 PM   #30
IN AN ICE DAM situation,it takes more than workmanship,the specs and material used,usually make up the difference,Indiana doesn`t get quite as much frigid weather,so you can get by with lighter specs,more northern areas need these things-gaf weather watch is a good product as aaron alludes to-this topic is from last year!
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
Lathe metal roofing? Stan ETenn Roofing/Siding 19 06-18-2013 06:48 PM
Choosing The "Right" Roofing Contractor, How To Evaluate Who Is Right! Ed the Roofer Roofing/Siding 27 04-25-2013 05:10 AM
Roll Roofing Repair IfItAintBrokeFixItAnyway Roofing/Siding 9 09-13-2009 05:32 PM
Metal Roofing for Experienced Beginners rezroofers Roofing/Siding 3 06-20-2007 11:42 PM
What roofing material is right for me? Grumpy Roofing/Siding 0 07-07-2004 07:41 PM
