Roofing Material For Less Than 3:12 Pitch - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-20-2009, 10:12 AM   #1
Roofing material for less than 3:12 pitch
The Patio roof will have a 2.5:12 pitch due to the location of the window on an existing wall. So I can't put a shingle roof (Voids warranty if the pitch is less than 3:12). The other option being a metal roof. But I read that metal roof makes lots of noise during rain.
I am looking for any suggestions on what is the best roofing material that i can use
seth is offline   Reply With Quote
Old 07-20-2009, 11:02 PM   #2
Even some metal roofs aren't recommended for use under a 3/12 because of the way that they lap together. Low slope metal is available but it's more money. I've never actually worked with it.
I'm not sure if the IKO iceguard (peel and stick) underneath a low slope shingle would work. You'd have to check with your building supply store.
P.S. - Isn't there a roofing forum?
the carpenter is offline   Reply With Quote
Old 07-21-2009, 06:55 AM   #3
I would not recommend a metal roof as you still don't have enough pitch. I would also not try to lay shingles on it even with a peel and stick membrane. Where do you live? Those membranes will leak if you live in a colder climate. Install a piece of EPDM. You can order one big sheet without any seams and you will have no chance of leaks.
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
Old 07-21-2009, 07:00 AM   #4
I live in atlanta ga. Do you mean use EPDM and lay single on top of it?
Old 07-21-2009, 07:14 AM   #5
Not so new
12penny's Avatar
Rewards Points: 520
seth....try www.fabral.com. This is the most cost effective standing seam metal roof I could find. Can be used on roof pitches down to 1:12.
With a low slope, its all in the flashing detail.
12penny is offline   Reply With Quote
Old 07-21-2009, 08:41 AM   #6
No!!
framer53 is offline   Reply With Quote
re: roofing material questions gramps416 Roofing/Siding 6 06-30-2009 03:42 PM
Replacing Low Pitch Rolled Roof material jimmyfloyd Roofing/Siding 1 10-16-2008 04:03 PM
Recommended low pitch roofing! Wildie Roofing/Siding 5 09-15-2008 09:38 PM
Roll roofing material RedDawg454 Roofing/Siding 8 05-03-2007 06:52 AM
What roofing material is right for me? Grumpy Roofing/Siding 0 07-07-2004 07:41 PM
