Roofing Material - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-25-2010, 12:14 PM   #1
Roofing Material
What is the difference in quality between Heritage IV 30 year shingles and GAF 3o year Timberline Architectual Shingles?
Poopsie is offline   Reply With Quote
Old 08-25-2010, 12:38 PM   #2
Grumpy's Avatar
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
Look at the weights in regards to the volume of water proofing asphalt used in the construction of the shingle.
Does timberline has AR standard?
-Grumpy
Chicago Roofing Chicago Gutters
Sometimes the savings that comes from doing it yourself can be blown away with one mistake.
The information found in this post is not to be considered legal advice. All information should be considered relative, not specific. Never attempt any repairs you are not comfortable with. Always maintain safety! The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 08-25-2010, 03:46 PM   #3
Residential Roofer
Slyfox's Avatar
Just the looks.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Old 08-26-2010, 09:56 AM   #4
Grumpy's Avatar
I have to disagree with Sly. But it's not the first nor last time we will disagree. There are a ton of threads about this topic already so I won't bring it back up.
-Grumpy
Old 08-26-2010, 12:12 PM   #5
Thrasher
No differences because they are both inferior to Certainteed Landmark shingles
Lulimet is offline   Reply With Quote
Old 08-26-2010, 12:53 PM   #6
Rewards Points: 956
i hear certainteed is the best too
federer is offline   Reply With Quote
Old 08-26-2010, 04:34 PM   #7
Doing This Way Too Long
Rewards Points: 532
All depends on the region. Been putting GAF/Elk on here for more than 20 years. Much more popular than CT. I personally have never had a material issue with either in all that time.
Grumps, AR is not required everywhere. Not used here because it's completely ineffective.
OldNBroken is offline   Reply With Quote
whats the cost for material and labor for TPO roofing mario martinez Off Topic 1 08-12-2010 06:08 PM
Roll Roofing Edge Leak toolboxone Roofing/Siding 5 10-07-2009 07:09 AM
Roofing material for less than 3:12 pitch seth Roofing/Siding 5 07-21-2009 09:41 AM
Roll roofing material RedDawg454 Roofing/Siding 8 05-03-2007 07:52 AM
What roofing material is right for me? Grumpy Roofing/Siding 0 07-07-2004 08:41 PM
