Roofing Leaks - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-17-2012, 04:11 AM   #1
Roofing leaks
I just have registered in this forum and hope I would get a better solution to my roofing problem. During rain, the water is leaking from the ridge vent down to the attic. I did an inspection and found that there were two pieces of ridge vents butted together with the cement that has been cracked. I tried patching it up with sealant, but it did not help. Anyone had a similar issue? If so please explain how you resolved it. Thanks in advance for your advice.
smithleeds42 is offline   Reply With Quote
Old 08-17-2012, 09:47 AM   #2
chb70's Avatar
Upload a picture so we can see what it looks like.
But it sounds like the ridge vent you have should overlap when sectioning together.
RSC Builders, Inc
Can You Dig It!
Complete Roof
chb70 is offline   Reply With Quote
Old 08-17-2012, 10:04 AM   #3
Rewards Points: 14,300
I've never seen a ridge vent that needed to be glued in anyway. The ridge cap shingles should be cover up any joints.
If someone cheaped out and used 3 tab shingles sometimes they will crack.
If someone cut the sheathing back to far at the peak it would leave a wide open area for water to get in.
Old 08-17-2012, 11:50 AM   #4
chb70's Avatar
That's why we need to see a picture. I thought he was talking about the older style metal ridge vents.
RSC Builders, Inc
Can You Dig It!
Complete Roof
Old 08-17-2012, 11:56 AM   #5
Rewards Points: 150
Also a pic from in the attic looking up at the peak
Hammer450R is offline   Reply With Quote
Old 08-17-2012, 12:23 PM   #6
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
It's a spam post guys. This idiot also posted an 'answer' in th esecond post taking you to a another place. His/her twin posts are elsewhere too.
A fake question and link answer. I had reported this post too, but it's still here for some reason.
tinner666 is offline   Reply With Quote
Old 08-17-2012, 03:04 PM   #7
chb70's Avatar
Thanks Tinner
RSC Builders, Inc
Can You Dig It!
Complete Roof
Old 08-17-2012, 04:20 PM   #8
Rewards Points: 150
May your roof leak on your lap in the middle of the night so your wife thinks you wet the bed!!!
The Following User Says Thank You to Hammer450R For This Useful Post:
Gymschu (08-17-2012)
Old 08-18-2012, 02:11 PM   #9
RFN-4A-LVN
Roofmaster417's Avatar
May all their children be born naked.
Roofmaster417 is offline   Reply With Quote
Choosing The "Right" Roofing Contractor, How To Evaluate Who Is Right! Ed the Roofer Roofing/Siding 27 04-25-2013 05:10 AM
Manufacture History Roofmaster417 Roofing/Siding 6 02-23-2012 02:40 AM
Roofing Material History Roofmaster417 Roofing/Siding 4 09-08-2011 04:49 PM
Multiple Roofing issues on my home. *HELP!* 2bsure Roofing/Siding 4 12-16-2009 09:29 PM
Roll Roofing Edge Leak toolboxone Roofing/Siding 5 10-07-2009 06:09 AM
