Roofing Leaking Under Flashing/With Pics - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-09-2012, 02:55 PM   #1
My roof has recently just started to leak. I can see signs where the front interior living room wall meets the ceiling. It has recently stormed very bad including flash flooding, heavy rains, heavy winds, power outages, etc. From the attached pics it appears that water has gotten under the flashing. I took pictures of the wood under the flashing but they did not come out clear, but when i bent up the flashing, I could see the wood. How do I fix this?
Any help/guidance is appreciated.
Thank you.
Roofing Leaking Under Flashing/With Pics-2012-09-09_10-52-40_94.jpg   Roofing Leaking Under Flashing/With Pics-2012-09-09_10-56-36_908.jpg
phillysfinest4 is offline   Reply With Quote
Old 09-09-2012, 07:45 PM   #2
Rewards Points: 13,444
You have three differant things going on there.
Flashing was installed wrong.
The shingles should have been so it cover the flashing.
Your missing about a foot of drip cap.
Old 09-09-2012, 07:51 PM   #3
Thank you. Would you be able to explain to me how to fix it? Or point me in the right direction?
pressure relief valve is leaking on boiler wlmpdiycr HVAC 65 10-26-2011 05:00 PM
Leaking Pipe above hot water heater with pics notarock Plumbing 9 07-30-2011 08:29 PM
Cold Ap Roll Roofing CarlosHRNYC Roofing/Siding 1 04-29-2011 06:50 AM
Getting a new roof........what to ask, what to look for? HautingLu Roofing/Siding 10 05-25-2009 12:45 PM
New Roof Jeff DIY Roofing/Siding 7 04-08-2009 03:01 PM
