Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 05-04-2007, 06:55 PM   #1
roofing job okay so far?
Hi all,
We hired a roofer we felt good about, had good references, etc., who subbed the job -- he said they'd do a great job, etc. They're part way throught the job-- dimensional shingles on an old house in 70-ish degree weather -- and we're disappointed to see the shingles not laying flat. We don't know if it's a bad job at this point, or if we just need some hot days for the shingles to settle down-- there are pics at the following link if anyone would care to offer advice.
We have't paid anything on the job yet, and we're thinking we don't want to pay the full price until it looks good --hopefully the job is well done in terms of rain protection, not just cosmetics, but we don't have the expertise to tell.
Thanks for any info--
link to pics:
http://mandolinbridge.net/2.html
foursquare is offline   Reply With Quote
Old 05-04-2007, 08:43 PM   #2
I have a few questions about the agreement you made..
Why did you hire a guy who hired a guy?...unless the roof was part of a larger job run by a general.
Did they offer to do a tearoff and re-roof, and you didn't want to pay extra?
Did you sign a contract with a detailed scope of work, and does the detail include tearing off old roof?
Are these contractors licensed?
send_it_all is offline   Reply With Quote
Old 05-04-2007, 09:09 PM   #3
we didn't realize, when we hired the guy, that he wouldn't be at the job site himself. We had a level of trust in him, so when he said he was having the work done by another guy he uses, we weren't too concerned.
I did speak with the original roofer this evening, & he said the shingles would lay down with a few warm days--I've been researching the internet & found this is true, so we may be fine. Roofers should warn their clients about this, it's a shock to see shingles looking like that!
The guy is a member of NARI (I believe that's correct, I think it's a roofing association), has a good record with Angie's List locally, & no problems with the Better Business Bureau. He also provided a recent address they roofed & it looked great. He looked good on ServiceMagic as well, who stated he carried up to date insurance. (I know we should have demanded proof, we'll get tougher about that).
We did sign a contract stating the work to be done--there's one layer of tab shingles on the roof, so shingling over that shouldn't be a problem, though there seems to be controversy on that. The current layer of shingles were in decent shape. One company that bid suggested a tear off, but they didn't have a good track record.
Since I've found out about shingles needing a day or two of hot weather to "lay down", I'm feeling better about all this. Time will tell, we've got some warmer weather coming.
Old 05-04-2007, 09:13 PM   #4
I think it will be fine, too.
I'm not a roofer, though...lol
Old 05-04-2007, 09:20 PM   #5
Super Moderator
Reroofing over an existing roof will create a slightly more bumpy appearance if the pre-existing shingles were already beginning to curl, claw or buckle.
Some of the lifting observed in the center of the new shingles may be due to being butted too tightly together or also from following the nesting pattern from the previous roof. The original 3 tab shingles have slots every 12 " which can accomodate some minor horizontal variences of the rows. If the new architectural shingles were following a wavy row, that could possibly account for the center bridging I noted on several of the shingles.
Also, it just may need to warm up a little more for then to lay down flatter.
It really all comes down to; What did the contract specifications say thay would do.
Minor cosmetic irregularities are not a warrantable byproduct of the installation, but more significant aesthetic problems which could adversely affect the weather proofing of the entire roof system should be held to a different standard.
BTW, just today our company is starting a new roof tear-off on an exact twin to the roof in your photos, including the offset roof at the top where the sheet metal flashings and brick chimney are located.
That one is in Elgin, IL.
Also, NARI stand for National Association for the Remofeling Industry. Were you thinking of NRCA, the National Roofing Contractors Association instead? He could belong to NARI, as they have a specialized trade program available too.
Ed
Ed the Roofer is offline   Reply With Quote
Old 05-05-2007, 10:13 AM   #6
thanks guys!
I believe it was NARI he belongs to--his company is listed as roofing & remodelling, but I don't believe he remodels any more. (getting older, which may explain why he didn't work on this roof & hired the other guys).
Ed, how are you handling the flat roof area? Our guys aren't dealing with it all (contract didn't specify anything about it)--& he said the flashing around the chimney & flues was fine, but the only leaking problem we have is the chimney wicking moisture down to the 2nd floor. Roofer thought the moisture was coming from rain entering the flues. We put a chimney cap on one flue, (& will do the other as well). The exposed chimney in the attic shows a lot of deterioration of the mortar--at 100 years, I wonder if the brick & mortar is sucking up the moisture rather than the flashing leaking.
In any case, we're thinking of using another local company, larger & very reputable, to address that flat area of roof.
Old 05-05-2007, 11:03 AM   #7
Super Moderator
The roof section at the top by the chimney is not actually flat in my situation. Maybe yours is, but I didn't notice that from the thumbnail photos.
We are using Grace Ice and Water shield and shingling the one on the home we are doing.
Old brick does wick substantial moisture. If the tuckponting is in good shape, then a water repellant coating should be applied to the exterior of the masonry surfaces. This is not a long term solution and will be necessary to re-apply every 5 years or so.
Ed
Old 05-05-2007, 02:19 PM   #8
thanks Ed!
(re: the thumbnails-the pics in the link can be enlarged, you have to click on them twice or so.)
Old 05-05-2007, 06:05 PM   #9
Ed- If the severely buckled/fishmouthed shingles remain open rather than lay down and seal, how does this affect weatherproofing?
Similiarly, how do 1" to 2" gaps at the rake edges caused by buckled shingles affect weatherproofing there?
Many Thanks.
itwerx2 is offline   Reply With Quote
Old 05-05-2007, 07:36 PM   #10
What was the current roof put over? The roofing looks like it was put over wood shingles or curled asphalt shingles.
Ron
Old 05-05-2007, 08:23 PM   #11
Super Moderator
Shingle roofs are weather proof only due to the slope that they are installed on. The shingles will probably lay down more and unless you are in a heavy wind tunnel area, it is probably not a major concern.
You have no "Rake edges" on your home. That term describes a gable style home, yours is a "hip" style.
Ed
Old 05-06-2007, 12:52 PM   #12
Ron6519, it was put on a pretty flat single layer of tab shingles. (I think they're tab, they're pretty old. A little curling & algae in the back of the house, but most of the pics aren't of the back.) I'm hoping that the new dimensional shingles were that wavy before they put them on--the shingles sat in the back yard for several weeks before they could get to this job, so they weren't laying flat in the bundle.
We have a couple of nearly 80 degree sunny days coming this week, so I think we're going to know more then. . .the roofer wanted payment in full on completion of the job, the decision we're wrestling with now is, to pay the full amount or pay partially until the shingles lay down to an acceptable level. . .
Old 05-07-2007, 09:14 AM   #13
MJW
Where are you located? I understand the IRC code says "no overlays". I had to correct the last building official on this last week. They had a pamphlet for their roofing projects in their area and it showed an overlay.
It is possible this is a MN thing though. I may have to correct myself after I find out the specifics.
MJW is offline   Reply With Quote
Old 05-07-2007, 09:46 PM   #14
Super Moderator
I am just curious, how many other sites did you post this question on and where do you feel you recieved the most correct answers from. I would like to add those to my favorites to visit on occasion too.
Plus, you did not mention in your post here on this site, that they did tear out some but not all of the ridges and valleys.
Ed
Expert: Stan Skarbek
Date: 5/4/2007
Subject: is this a bad roofing job in progess?
Question
We hired a roofer to put our roof on (dimensional shingles over one layer on an older home), and to our dismay the result so far looks, well, not too good. Is this a bad job in progess, or will it take warmer weather & sun for the shingles to lay flat? They started out not tearing off the ridges & valleys, but we asked them to do so on the areas they've not done yet. The job isn't quite completed, I have some photos showing the original shingles which mostly laid flat & smooth.
We're not sure how we should handle things at this point--the guy we contracted with is out of town & won't be back for a few weeks. We haven't paid any money yet.
Here's pics:
thanks!
Old 05-09-2007, 04:33 PM   #15
Hi guys,
sorry about the delay in response, we've been busy!
The job finished up yesterday, and the roof looks really good now--I think we (being first time roof customers) didn't realize how funky the shingles would be before they lay down, with the weather not being that warm. It's warmer now & it looks better & better.
Ed, that other site (Allexperts) was the only other one I posted on. I got a *lot* of good information from Stan, I spent a couple of hours reading his responses to lots of questions. I got good info here as well, and thank you for your input!! When I got several answers from roofers about the warm weather & the shingles laying down, I stopped worrying about the job. The roofers did tear off the ridges after we asked them to (they may have roofed one or two at that point), but none of the ridges look bad, considering it's a 2nd layer on asphalt shingles.
When reading Stan's info on ventilation, I realized we have a good thing in a working attic fan (just got this one fixed, it didn't work when we moved in)--and we were spending $200 on 4 static roof vents. I asked our roofer if both vents & attic fan would be redundant, and we decided not to install them, with the idea of installing soffit vents a bit later, so we saved a couple hundred bucks on that.
Re: the legality of more than one layer here (Southwestern Ohio)--I'm pretty sure it's okay, but I went to our (new) town's website & looked & looked in the regulations, could'nt find a thing anywhere about it. It's a common practice here though. I've heard you can have up to 3 layers here, but I'm not totally sure.
All in all, we feel good about this roofing job, they cleaned up well & were nice guys. I learned a heck of a lot in the process--especially about hiring contractors next time, asking the tough questions & checking work & references.
Choosing The "Right" Roofing Contractor, How To Evaluate Who Is Right! Ed the Roofer Roofing 27 04-25-2013 06:10 AM
Roll Roofing Repair IfItAintBrokeFixItAnyway Roofing 9 09-13-2009 06:32 PM
SPF Foam Roofing on Gables? WhyMeWhyNow Roofing 3 07-25-2005 06:31 PM
Lathe metal roofing? Stan ETenn Roofing 8 02-18-2005 03:51 PM
What roofing material is right for me? Grumpy Roofing 0 07-07-2004 08:41 PM
