Roofing How Many Nails? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-06-2011, 08:26 AM   #1
roofing how many nails?
does the benfit of using 6 nails verus 4 nails per shingle worth the extra cost. is 6 nails really worth it does it make that much difference
huxhold1 is offline   Reply With Quote
Old 08-06-2011, 08:45 AM   #2
Residential Roofer
Slyfox's Avatar
Depends.
Is your roof a steeper slope?
Do you have an open field or body of water near by?
Do leave in an area known for high winds?
Yes, six is better if you answered yes to any of the above.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
The Following 2 Users Say Thank You to Slyfox For This Useful Post:
Roofmaster417 (08-06-2011), seeyou (08-06-2011)
Old 08-06-2011, 05:02 PM   #3
RFN-4A-LVN
Roofmaster417's Avatar
Sly is right on.
Making sure those extra nails are in the proper nail location is important too.
Roofmaster417 is offline   Reply With Quote
Old 08-06-2011, 08:30 PM   #4
Yes it is better to use six nails. Also, some manufacturer's offer higher wind warranties if you 6-nail the shingles.
Omegaroofer is offline   Reply With Quote
Old 10-05-2011, 04:17 PM   #5
Hello All...I'm a newbie here and in the middle of a roofing project and need some assistance. I just built a 30'x15' patio cover where I came off of the house rafters by attaching 2x6's to them with 1/2" lag bolts. I put 1/2" CDX for the roof and just finished the tar paper. Being in Oregon, of course it rained on the new tar paper (felt) but I've read that is not a big deal as long as I wait until it's dry to put the shingles on. The issue I'm faced with is nailing the shingles to the roof. I really don't want the roofing nails to come through the 1/2" CDX and be visible. The slope is roughly 2:12.
Any thoughts or suggestions would be greatly appreciated.
Rick
Rknea is offline   Reply With Quote
Old 10-05-2011, 04:25 PM   #6
Framing Contractor
Rewards Points: 120
Add a second layer of plywood. The nails need to penetrate deeper into the plywood than 3/8" Or you can install vinyl soffit panels underneath to hide the rafters and the nails.
sixeightten is offline   Reply With Quote
Old 10-05-2011, 04:33 PM   #7
Patio Cover Nails
There are 17 rafters that the plywood is nailed to. Would it suffice to use those as "nail points" instead of going through the plywood? That would probably be out of code wouldn't it?
Thanks!
Rick
Old 10-05-2011, 04:36 PM   #8
Framing Contractor
Rewards Points: 120
That will definitely not work with shingle nailing. Why the big deal about not seeing the nails? Your gonna see the bottom of the plywood and all the rough 2x6 rafters anyway.
Old 10-05-2011, 04:40 PM   #9
Patio Cover
We've primed and painted the plywood and rafters to lighten up things a bit. Hmmm...looks like I'm going to have to look at vinyl soffet panels. Uggh...
Old 10-05-2011, 04:41 PM   #10
Framing Contractor
Rewards Points: 120
Any thoughts about adding a layer of plywood?
Old 10-05-2011, 04:47 PM   #11
Patio Roof
That's an option I suppose but I already have the roofing felt down. I would have to rip that off, nail plywood to the existing CDX, and re-felt. OR...put some plywood in for a "ceiling" I suppose?? I've been so careful with every step of this project...but this one has just taken a bite out of my rear!!
Old 10-05-2011, 04:49 PM   #12
Framing Contractor
Rewards Points: 120
Maybe you should just roof it and see how much you really notice the nails. Probably not as much as you think.
Old 10-05-2011, 05:12 PM   #13
Rewards Points: 150
A lot
OhioHomeDoctor is offline   Reply With Quote
Old 10-05-2011, 08:42 PM   #14
spray paint underneath when you are done.
Old 10-06-2011, 09:50 PM   #15
Registered User
Rewards Points: 526
May as well build to minimum Code; http://publicecodes.citation.com/ico...005_par007.htm
Double coverage on the felt for your low slope; http://publicecodes.citation.com/ico...005_par009.htm
Did you add some support under each new rafter with framing over the house exterior wall? Your house rafters may not take the added load….
Permits are nice for a paper trail in case of insurance claim and when selling.
Gary
Roofing nails GerryinBelleRiv Roofing/Siding 5 08-14-2009 05:41 PM
Source for roofing nails, 3" long, ring shank? buzzymalone Roofing/Siding 7 07-27-2009 10:58 AM
sizing roofing nails rebel Roofing/Siding 15 03-05-2009 03:05 PM
which roofing nails for pressure treated lumber ? amakarevic Building & Construction 11 01-30-2009 03:26 AM
Coiled roofing nails for nail gun twaters12 Roofing/Siding 3 02-06-2006 07:37 PM
