Roofing Felt Installation Question - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-25-2012, 11:51 AM   #1
Rewards Points: 12
I am installing roofing felt on my shed today. I just wanted to make sure I install it correctly. I have a fairly steep roof (10 in 12). Do I install the felt with an overhang? How much overhang do I use for the felt? Is 1/2" - 1" alright? Also, when I install my shingles, do I match my shingle overhang with the felt overhang or do I use more overhang for the shingles? How much overlap do I need on my steep roof for the felt rows? Thanks in advance.
MrUnderhill is offline   Reply With Quote
Old 09-26-2012, 11:52 PM   #2
Rewards Points: 16
Step1 Rip/clean/cut 3inch whole in peak for rollvent/ventilation roof
step2 Install bottom metal (1inch overlap)
Step3 Install ice and water shield on bottom of roof over metal
step4 Installed felt/under layment
step5 install metal up gabals
Step6 snap bottom line for your overhang (1/4in for steep roof)
step7 2 options, make sure your paper goes on straight or snape lines up the whole roof and have fun :D
vandel777 is offline   Reply With Quote
The Following User Says Thank You to vandel777 For This Useful Post:
MrUnderhill (09-27-2012)
Old 09-27-2012, 06:13 AM   #3
Roofer Mike
1/2"-3/4" is fine till you install your drip edge metal flashing. Assuming you have a fascia, a 1"X2" firring strip should be nailed along the top edge of the fascia to provide a gap between the metal and fascia. This prevents rain/ice from flowing off the roof & onto the wood fascia. Felt should not extend beyond the firring strip since it will prevent flush mount of metal.
Like Roofer Mike Inc at https://www.facebook.com/pages/Roofe...37625929645476
http://www.roofermikeinc.com/
roofermikeinc is offline   Reply With Quote
The Following User Says Thank You to roofermikeinc For This Useful Post:
Old 09-27-2012, 07:38 AM   #4
Rewards Points: 83
Overhang the felt on the eve by an inch. Do not overhang felt on the gable (sides).
Install the shingles/starters on the edge of felt.
Overlap your felt rows by 2"
bcdemon is offline   Reply With Quote
The Following User Says Thank You to bcdemon For This Useful Post:
is roofing felt necessary for a 8x12 shed? jmoney Building & Construction 8 06-16-2010 03:46 PM
Tyvek and roofing felt bamaranch Building & Construction 17 05-26-2010 03:00 PM
Fence Post Installation Question Jawbreaker Landscaping & Lawn Care 6 04-08-2010 10:46 AM
Roofing Felt ? tonyews Roofing/Siding 8 11-21-2009 10:16 AM
Roofing over old felt!! bandit55 Roofing/Siding 65 06-03-2009 11:44 AM
