-   -   Roofing Felt Installation Question (http://www.diychatroom.com/f9/roofing-felt-installation-question-157948/)
MrUnderhill 09-25-2012 11:51 AM
I am installing roofing felt on my shed today. I just wanted to make sure I install it correctly. I have a fairly steep roof (10 in 12). Do I install the felt with an overhang? How much overhang do I use for the felt? Is 1/2" - 1" alright? Also, when I install my shingles, do I match my shingle overhang with the felt overhang or do I use more overhang for the shingles? How much overlap do I need on my steep roof for the felt rows? Thanks in advance.
vandel777 09-26-2012 11:52 PM
Step1 Rip/clean/cut 3inch whole in peak for rollvent/ventilation roof
step2 Install bottom metal (1inch overlap)
Step3 Install ice and water shield on bottom of roof over metal
step4 Installed felt/under layment
step5 install metal up gabals
Step6 snap bottom line for your overhang (1/4in for steep roof)
step7 2 options, make sure your paper goes on straight or snape lines up the whole roof and have fun :D
roofermikeinc 09-27-2012 06:13 AM
1/2"-3/4" is fine till you install your drip edge metal flashing. Assuming you have a fascia, a 1"X2" firring strip should be nailed along the top edge of the fascia to provide a gap between the metal and fascia. This prevents rain/ice from flowing off the roof & onto the wood fascia. Felt should not extend beyond the firring strip since it will prevent flush mount of metal.
Like Roofer Mike Inc at https://www.facebook.com/pages/Roofe...37625929645476
http://www.roofermikeinc.com/
bcdemon 09-27-2012 07:38 AM
Overhang the felt on the eve by an inch. Do not overhang felt on the gable (sides).
Install the shingles/starters on the edge of felt.
Overlap your felt rows by 2"
