Roofing Delima - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-11-2007, 09:28 AM   #1
Darylh's Avatar
Roofing Delima
Okay here is the problem, I have a 4/12 pitch roof and presently it has butt shingles. Where the garage starts the roof has a very slight turn maybe 3-4 degrees( its like a mini valley towards the front of the house) . The past installer overlapped the joint and we do not like this. I have to put a new roof on this year and looking for ideas on what to do about this joint. I will be using butt shingles. Look foward to your input.
Darylh is offline   Reply With Quote
Old 02-11-2007, 10:34 AM   #2
Commercial Roofing
AaronB's Avatar
What do you mean by butt shingles, and do you have a close up?
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 02-11-2007, 10:43 AM   #3
Darylh's Avatar
Sorry, thats short for what they call them up here.
Old 02-11-2007, 11:09 AM   #4
Darylh's Avatar
Okay now that its daylight here is a few pics. I have a few ideas but wanted to get some input as to what others might do in case I havent thought of something.
Old 02-12-2007, 07:47 AM   #5
Commercial Roofing
AaronB's Avatar
Ahhh...a little valley. Ice barrier, metal, and open valley if you do not like the closed cut valley. You could weave the valley, but I dont like that method either.
Old 02-12-2007, 08:09 AM   #6
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
When you say he 'overlapped' the joint, do you mean you have a cut shingle line down the valley? Thats a pretty robust way to do it. You have a low pitched roof. An open valley could leak easier. Do you get snow in Vancouver BC? I suspect so. I dams could cause issues easier with an open valley. If you do not like that cut line then weave them AND use an ice/water shield membrane.
Brik is offline   Reply With Quote
Old 02-12-2007, 08:14 AM   #7
Darylh's Avatar
What is a closed valley?.
I thought about the weaved way but have not decided how that will look
Old 02-12-2007, 08:25 AM   #8
Handyguy
Brik's Avatar
Closed would mean either weaved or overlapped in my terms. But whats technically called a "closed-cut" valley is where the shorter roof is shingled across the valley and up the other side. Then the larger roof is shingled across the valley, a chalk line is snapped down the valley (2" or so offset from center) and the top layer of shingles is cut to that line. Nail placement is important in this type of install (None within 8" of center of valley).
Regardless - I think you job calls for a woven, closed, valley. I think it would look best unless you want to highlight the jog in the house for some reason.
Old 02-12-2007, 08:43 AM   #9
Darylh's Avatar
This makes a lot of sense to me, No I am trying to hide this as much as possible. I first was going to have a open valley and then realized a open valley on a low pitch with just a slight turn would most likely have issues later so this sounds like the way to go. So in the meantime thanks to all and we will see if any other ideas pop up. I don't think there is any other way.
Old 02-12-2007, 09:52 AM   #10
Rewards Points: 774
Regardless of look, if you want it done right a closed valley (woven...each shingles is overlapped forming a slight "v" in the valley) is the way to go. Anything else is asking for leaks.
cibula11 is offline   Reply With Quote
Lathe metal roofing? Stan ETenn Roofing/Siding 19 06-18-2013 06:48 PM
Choosing The "Right" Roofing Contractor, How To Evaluate Who Is Right! Ed the Roofer Roofing/Siding 27 04-25-2013 05:10 AM
Roll Roofing Repair IfItAintBrokeFixItAnyway Roofing/Siding 9 09-13-2009 05:32 PM
SPF Foam Roofing on Gables? WhyMeWhyNow Roofing/Siding 3 07-25-2005 05:31 PM
What roofing material is right for me? Grumpy Roofing/Siding 0 07-07-2004 07:41 PM
