Roofing Boot Repair - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-04-2013, 05:23 AM   #1
roofing boot repair
check out my new roofing video for homeowners. I hope this helps http://youtu.be/BxI-6A7qLM
Last edited by oh'mike; 05-04-2013 at 06:25 AM. Reason: removed link --please read posting rules
roofguy1000 is offline   Reply With Quote
Old 05-04-2013, 06:17 AM   #2
Rewards Points: 2,240
Interesting!
Not quite the way I would do it!
However, to each - his own.
rossfingal is offline   Reply With Quote
Old 05-04-2013, 11:53 AM   #3
Roofmaster
Rewards Points: 2,210
1. You are not supposed to put nails in the lower corners.
2. I would envelope the flange in ice dams after nails, but thats me.
The Following User Says Thank You to jagans For This Useful Post:
rossfingal (05-04-2013)
Old 05-04-2013, 05:52 PM   #4
Household Handyman
Rewards Points: 1,408
That method would not pass inspection here. The bottom half of the boot cover may not be covered with shingles here.
Old 05-05-2013, 10:39 AM   #5
Also, the overlap on the bottom flange of the boot -
probably, should have another course of shingles under it.
Old 05-06-2013, 03:57 PM   #6
Metal Roofing
Rewards Points: 600
I see those boot type flashing a lot, but all metal flashing are the bulk of what we see in CA. If it were me, and it was my house, wouldn't you put an all metal flashing and storm collar instead of the boot type.
Not having used the boot types much at all, i don't really trust them. Whats the consensus on boot vs all metal type flashings...do they last or as we see in his vid do they fail more than the all metal type?
I dont think i ever get easy leak calls like whats in the vid, it is usually installation errors, improper tie in to a new addition, a hack or a HO repair job.
AndyWRS is offline   Reply With Quote
Tags
roofing boot repair
Rolled roofing vs metal roofing Kelly56 Roofing/Siding 2 04-08-2013 08:19 PM
Is Black Jack Asphalt based roofing cement okay for repairing holes in roofs? amodoko Roofing/Siding 5 11-10-2012 10:10 AM
Repair Already Installed rolled roofing bobmartinez Roofing/Siding 1 10-18-2011 04:08 PM
Roofing Company Refuses to Quote for ... Dodah Roofing/Siding 11 06-03-2009 06:17 PM
Roofing felt mattflytx Roofing/Siding 2 09-09-2007 11:01 PM
