Roofing - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-10-2005, 10:52 PM   #1
roofing
I have a deck that I would like to install a trussed roof over. It would be perpendicular to existing roof. How do you tie in to existing wall and roof with beams? or do they use posts?
clockmaster is offline   Reply With Quote
Old 01-28-2005, 09:35 PM   #2
Commercial Roofing
AaronB's Avatar
I think you need to go to the carpentry section.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 02-13-2006, 02:36 PM   #3
Send a message via AIM to spacedout
Depending on the situation i would set two posts on the outside edge of the patio then i would tie beams into the wall with hurricane ties and possably put posts under them too run truses from the posts back to the house and stick frame it into the house roof. What kind of siding is on the house and how big is the new roof?
spacedout is offline   Reply With Quote
Lathe metal roofing? Stan ETenn Roofing/Siding 19 06-18-2013 06:48 PM
Choosing The "Right" Roofing Contractor, How To Evaluate Who Is Right! Ed the Roofer Roofing/Siding 27 04-25-2013 05:10 AM
Roll Roofing Repair IfItAintBrokeFixItAnyway Roofing/Siding 9 09-13-2009 05:32 PM
SPF Foam Roofing on Gables? WhyMeWhyNow Roofing/Siding 3 07-25-2005 05:31 PM
What roofing material is right for me? Grumpy Roofing/Siding 0 07-07-2004 07:41 PM
