Roofing - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-24-2014, 09:17 AM   #1
Rewards Points: 12,830
Roofing
Just the thrill of having to replace 30 sq. of shingles on the home I share with my lady friend last week.
They had built additions on the front and back of the home many years ago with about a 2-12 pitch and had used 3 tab shingles with all the glue lines exposed because they had set the exposure at 6" instead of the required 4" on a low slope roof.
They had H clips on only half the roof.
Stamped right on the plywood it was stamped "reject" right over the grade mark.
There was no spacing between sheets.
Some areas had 5 layers of tar paper other's had none.
They had made there own step flashing out of what looked like paper thin aluminum flashing, then nailed into where it was bent 90 deg.
There was an old repair where an old chimney had been and they just used a bunch of nails at an angle to support it and had tarred it in place, so all you had to do was push on it to get it to fall through.
There was 0 insulation over the ceiling.
Only used 2 nails on each piece of 10' long drip edging.
Flashing on the chimney was done with the same paper thin flashing, not cut into the mortar joints, and just nailed to the block with ungalvinized roofing nails.
The rafters did not even run out so they would sit on top of the walls, where tapered to nothing and where just resting on top of the plywood ceiling.
Gee I wonder if a first time DIY did this one?
Windows on Wash (04-24-2014)
Old 04-24-2014, 11:10 AM   #2
Rewards Points: 768
You can't teach common sense
cibula11 is offline   Reply With Quote
Old 04-24-2014, 11:30 AM   #3
Rewards Points: 144
I feel your pain Joe.Unfortunetly I see way to much of this myself.Not on my own house though these days.I've taken care of most of it the last few years.I do still have a set of stairs on my back porch you would get a kick out of.
mako1 is offline   Reply With Quote
Choosing The "Right" Roofing Contractor, How To Evaluate Who Is Right! Ed the Roofer Roofing/Siding 27 04-25-2013 06:10 AM
Is Black Jack Asphalt based roofing cement okay for repairing holes in roofs? amodoko Roofing/Siding 5 11-10-2012 11:10 AM
Manufacture History Roofmaster417 Roofing/Siding 6 02-23-2012 03:40 AM
Roofing Material History Roofmaster417 Roofing/Siding 4 09-08-2011 05:49 PM
Roll Roofing Edge Leak toolboxone Roofing/Siding 5 10-07-2009 07:09 AM
