Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 09-12-2012, 01:47 PM   #1
roofing
When roofing over an existing roof, no leaks, do I need to re-flash around the chimney, or any other step flashing areas? DO I need to trim off shingles at roof line, and put drip edge?
douglas r is offline   Reply With Quote
Old 09-12-2012, 01:53 PM   #2
roofing
do i need to use felt paper 15 lb or 30 lb??? do i need to trim at gutter or go over , This is an old 3 tab roof only layer
Old 09-12-2012, 01:58 PM   #3
roofing
do i need to use felt paper 15 lb or 30 lb??? do i need to trim at gutter or go over , This is an old 3 tab roof only one layer with no leaks do i need to trim off edge of roof line and put drip edge ? do i need to re-flash around chimney or other step flashing areas
Old 09-12-2012, 01:59 PM   #4
roofing
Why are you not removing the old roof? No way to check for sheathing damage without removing the old.
Going to cost double at some point to remove two layers.
Sorry just not a big fan of roof overs.
No you do not have to reflash the chimmney.
No felt paper needed.
Just cut them even with the old shingles on the edges.
Old 09-12-2012, 02:05 PM   #5
roofing
I can see from attait no dis color wood looks great and will be selling so you say no new drip just shingle over as same.
Old 09-12-2012, 02:14 PM   #6
roofing
I'm re-roofing do I need to use felt paper ( forgot no leeks in old roof. all is well just want to catch it before bad it is old 3tab) or re-flash old flashing or drip edge what say you.
Choosing The "Right" Roofing Contractor, How To Evaluate Who Is Right! Ed the Roofer Roofing 27 04-25-2013 06:10 AM
Manufacture History Roofmaster417 Roofing 6 02-23-2012 03:40 AM
Roofing Material History Roofmaster417 Roofing 4 09-08-2011 05:49 PM
Multiple Roofing issues on my home. *HELP!* 2bsure Roofing 4 12-16-2009 10:29 PM
Roll Roofing Edge Leak toolboxone Roofing 5 10-07-2009 07:09 AM
