-   -   roofing (http://www.diychatroom.com/f9/roofing-156613/)
douglas r 09-12-2012 12:47 PM
roofing
When roofing over an existing roof, no leaks, do I need to re-flash around the chimney, or any other step flashing areas? DO I need to trim off shingles at roof line, and put drip edge?
douglas r 09-12-2012 12:53 PM
reroofing
do i need to use felt paper 15 lb or 30 lb??? do i need to trim at gutter or go over , This is an old 3 tab roof only layer
douglas r 09-12-2012 12:58 PM
reroofing
do i need to use felt paper 15 lb or 30 lb??? do i need to trim at gutter or go over , This is an old 3 tab roof only one layer with no leaks do i need to trim off edge of roof line and put drip edge ? do i need to re-flash around chimney or other step flashing areas
joecaption 09-12-2012 12:59 PM
Why are you not removing the old roof? No way to check for sheathing damage without removing the old.
Going to cost double at some point to remove two layers.
Sorry just not a big fan of roof overs.
No you do not have to reflash the chimmney.
No felt paper needed.
Just cut them even with the old shingles on the edges.
douglas r 09-12-2012 01:05 PM
I can see from attait no dis color wood looks great and will be selling so you say no new drip just shingle over as same.
douglas r 09-12-2012 01:14 PM
I'm re-roofing do I need to use felt paper ( forgot no leeks in old roof. all is well just want to catch it before bad it is old 3tab) or re-flash old flashing or drip edge what say you.
qtiproofer82 08-27-2014 02:26 PM
It's not a good idea to roof over. But if you do. Trim back shingles away from eave drip. Remove old ridge caps. Install new eave drip and flashing and new pipe flanges. Refelt roof with 15 or 30 lb felt. Use 1 1/2 roofing nails so new shingles will go through existing roof into decking.
ddawg16 08-27-2014 02:49 PM
When you do a roof over, you are doubling the weight on your roof.
And every roof over I've seen looks like crape. After a few days of sun, you start to see all the bumps and valleys of the old roof.
It's about par to painting your car without sanding it first.
If you're using cheap 3 tab shingles....it looks even worse.
1985gt 08-28-2014 01:32 PM
You can trim the first row of shingles so they but up against the 2nd course, and then continue on like. It will make the roof less lumpy but it's still a terrible idea and I feel sorry for who ever you pass this burden on to. Now they get to pay double to tear off a roof that you were to cheap to do correctly because "i'm selling it" I hope that you have to reroof it to close the sale and they reject it because you want to be a tight wad.
Oh and I forgot, make sure to use a double row of ice and water shield at all eve's and in the valleys also. I wouldn't use anything less then grace rip cord underlayment for the rest of the roof. All new flashing since it is a lay over is a must. I'd use copper, eve's rakes and chimney. Make sure that they are rigleted in to the block if applicable. Anything less and it's a waste of time even putting new shingles on. I like the Owens corning 3 tabs my self.
hotrod351 08-28-2014 01:46 PM
no felt, just roof over it, you know reroof is what its called. ive reroofed many homes and have never had a problem in 40 years. never. if anything you pick up some insulation form the old roof. there a roofing shingle called presidential shingles, 6 bundles per square, reroof and thats what you have, three bundles for the original roof and three form the new roof. it will never leak. unless you mess up something around the flashings. i always flash everything the same way as original roof, pry them up to get under them.
