Roofing 101 - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-24-2011, 02:05 PM   #1
Roofing 101
I've learned a lot over the last few years about roofing, unfortunately becausse I got burnt. What the 'last' contractor said, you should have had a roof ridge vent installed (explained what that was), but in my little blonde head thought, "shouldn't I have something at the bottom (vents) to push the cold air up and through the baffels I installed to exit out of the roof vent he wants to install? Yes, I said to myself. However, I have a CapCod, no soffits, I tried to researach "venting with no soffits" but they don't show 'pictures' of the products so I can see what type of product they are trying to sell. I tried looking on line, they all say you need soffits vents and roof ridge vents to properly keep the area functioning properly. Now, is there anyone out there who can suggest the "better" "Lower" roof installation of vents, thata would need to be cut into the roof, through the decking which would allow the air flow that I need so it would work properly? I've met with 17 roofing contractors, each gave me a bla bla bla and I need to do this... but when it is all said and done, this is MY asset and MY roof and I want it to work properly and not have some guy install 12 circular wind turbines at the lower end of my roof because he doesn't know any better. And, so the product doesn't leak would be nice.
Any knowledgalbe help would be appreciated.
thank you
leeeeeeo@aol.com
Diamonds07407 is offline   Reply With Quote
Old 04-24-2011, 04:57 PM   #2
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
As you've figured out, you need some sort of inlet for your ridge vent or other exhaust to work at full performance. If there's no soffit to vent, then vented drip edge (http://www.airvent.com/pdf/literatur...eSellsheet.pdf), low roof vents (http://www.cor-a-vent.com/in-vent.cfm) (http://www.dciproducts.com/html/smartvent.htm), or frieze vents (http://www.cor-a-vent.com/s400.cfm) are possible options. Also, low mounted turtle vents or dormer vents (http://www.grantlogancopper.com/dormers) might also be an option.
seeyou is offline   Reply With Quote
Old 04-24-2011, 11:52 PM   #3
This is what I have been using for the past 10 years in those situations exactly like yours.
Ed
Ed the Roofer is offline   Reply With Quote
Old 05-02-2011, 01:58 PM   #4
Grumpy's Avatar
Rewards Points: 540
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
You met with 17 roofing contractors?
WTF?!
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 05-03-2011, 11:22 AM   #5
RFN-4A-LVN
Roofmaster417's Avatar
WTF?!
I thought the norm was 15,,,,,Hahahahahaaha,,,,,,,,,,,,major time wasting IMO,,,,I have to admit,,,a local contractor installed a couple turbines about 4' off the gutterline on a home here in Springfield and everytime I drive by I laugh my a** off.I would like to thank him for bringing joy to my days.
Roofmaster417 is offline   Reply With Quote
Old 05-03-2011, 02:09 PM   #6
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
Originally Posted by styleroofingva View Post
Before choosing a (LINK REMOVED) for your home, it's always a good idea to compare prices and services in your area. If you're unsure or want further recommendations, check out what people are saying online about a (LINK REMOVED). If you still have questions shoot them a message. I'm sure they'd be more then happy to give you their honest opinion. If you still want to do-it-yourself, at least consult with one in your area before making any permanent changes. They'll be able to give you the best advice on how to make these repairs to your home.
Kinda loading one side of the roof a little heavy there, aren't you?
Old 05-03-2011, 05:17 PM   #7
RFN-4A-LVN
I moved the post and reposted under safety.
The Following User Says Thank You to Roofmaster417 For This Useful Post:
oh'mike (05-03-2011)
Old 05-03-2011, 05:23 PM   #8
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
Geeeezzzz,I seen something like that on 3 occasions ALL ending VERY badly.
I got that picture off of his homepage. Looks like he got banned from this forum since his posts just disappeared.
Old 05-03-2011, 05:59 PM   #9
RFN-4A-LVN
I moved the post and reposted under Safety
Tags
ridge vents , roof , shingles , soffit vents , vent
Choosing The "Right" Roofing Contractor, How To Evaluate Who Is Right! Ed the Roofer Roofing/Siding 27 04-25-2013 05:10 AM
Metal roofing questions Axhammer Roofing/Siding 17 08-10-2010 09:10 AM
Multiple Roofing issues on my home. *HELP!* 2bsure Roofing/Siding 4 12-16-2009 09:29 PM
Roll Roofing Edge Leak toolboxone Roofing/Siding 5 10-07-2009 06:09 AM
Roll Roofing Repair IfItAintBrokeFixItAnyway Roofing/Siding 9 09-13-2009 05:32 PM
