Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing/Siding
Old 06-27-2009, 07:26 PM   #1
RoofGaurd vs Felt paper
I am considering using either GAF Deck Armor or IKO Roofgaurd instead of felt paper when I reroof my home. Does anyone have experience with this product? Is it worth the extra cost over felt paper?
Thanks.
GerryinBelleRiv is offline   Reply With Quote
Old 06-28-2009, 01:00 AM   #2
I do use the Deck Armor quite often. The product is often used by renovators in my area because it is so tough to tear that they can use it on the roof until the reno is complete.
I have seen it protect a roof by itself for 3 months.
I have no experience with the IKO product but it sounds similar.
Felt works fine too. Felts do seem to vary between manufacturers.
We do not buy ours from the shingle manufacturers because there is an independent company locally that makes a much higher quality felt.
Dale Chomechko
DC Roofing Inc
Dale Chomechko is offline   Reply With Quote
Old 06-28-2009, 07:52 AM   #3
Deck Armor breathes and allows moisture to escape from underneath, while blocking water from above. Felt does not. However, deck armor considerably more expensive. I use it whenever possible.
Old 06-28-2009, 01:14 PM   #4
Residential Roofer
Slyfox's Avatar
How's the moisture get underneath if not through the material?
I have only used synthetics a couple times and I was under the impression it was suppose to be a water tight material, all tho I have never seen it in action because it did not rain on either roof that we used it on until after the shingles were installed.
Felt holds water out 'stops moisture from getting underneath' when properly installed and #15 felt will out last a 30 year shingle and a #30 felt will out last a 50 year shingle.
So unless your talking Tile or Slate that will set for a hundred years if properly installed and maintained then the regular old time tested and proven to work #15 and #30 felts are all you need.
Ofcourse in situations like mentioned by Dale in which the underlayment is going to be left exposed to the weather for a long period of time it would definately be worth the extra cost to use synthetics.
God Family Country Work Play
Slyfox is offline   Reply With Quote
Old 06-29-2009, 12:39 AM   #5
I am with you on this one Slyfox. I use Deck Armor by request usually but recommend TG2 or Malarkey UDL.
Deck Armor I do recommend for new construction though.
I live in a rain forest & almost everything is made of wood that needs to dry out as well as getting rained on.
If you had a roof that had ventilation issues this may not be a bad idea as well to help dry things out.
Dale Chomechko
DC Roofing Inc
Old 06-30-2009, 08:36 AM   #6
Thanks guys. I think I will save my money and use a quality felt paper.
felt paper or water & ice red86yota Roofing/Siding 11 02-20-2009 10:45 AM
Does felt paper allow a house to breathe? bluefitness Building & Construction 2 02-08-2009 09:42 AM
Is felt paper a sufficient vapor barrier for hardwood floor? jaj808 Flooring 15 03-27-2008 11:57 PM
Felt Paper 2007fxst General Discussion 6 12-11-2007 03:06 PM
Tar & Felt paper removal bhc65 Roofing/Siding 3 02-28-2007 04:12 PM
