Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 12-19-2011, 01:31 PM   #1
Roofer switched materials on me: wood vs metal on ridge beam
I'm getting a new roof installed on my house. I opted for the best materials on the entire job:
- concrete tiles
- polyfoam adhesive to set the tiles
- 170 mil modified bitumen
- 2 ply's in valleys,
- new skylight
- new roof vents
- metal ridge flashing to secure the ridge caps
The roof is nearly complete, with the entire installation done. A few tiles need to be replaced due to breakage during the pull test, followed by the final inspection and then final payment.
BUT, it just came to my attention that while the roofers were installing the tiles (I was out of the country at the time), they used pressure treated 2x4 wood to attach the ridge tiles instead of the metal ridge beams as specified specified in our contract.
How inferior of a product is the 2x4 vs the metal beam? I wanted the best of the best on this job, and didn't nickle and dime the roofer whatsoever. I'm very upset at this point and plan on requesting them to redo the ridge tile installation with the agreed upon material. But for my knowledge during discussions, how inferior is the wood to the metal?
Nikog is offline   Reply With Quote
Old 12-19-2011, 01:38 PM   #2
Low Slope Roofing
A 2x4 is not a flashing. The 2x4 is for that attachment of the tiles. A metal ridge flashing would be to close off or hide the 2x4. I would clear it up with the roofer first.
1985gt is offline   Reply With Quote
Old 12-19-2011, 01:43 PM   #3
Thanks for the reply. I understand that the 2x4 is for attachment of the tiles. During the roofer's sales pitch to me, they stated that they would use metal beams to install the ridge tiles, not 2x4's, as the metal is superior (won't warp over time).
Based on my witnesses who saw the tile installation, no metal beams were used for the attachment of the ridge cap tiles. The tiles were attached directly to the 2x4.
Old 12-20-2011, 08:48 AM   #4
Exterior Construction
Windows on Wash's Avatar
There should not be any issues with warpage of the installed 2x4s in this application if they are installed properly and the water details are correct.
Old 12-20-2011, 01:29 PM   #5
I wouldnt worry about warping either. Wood is the standard product for roofing construction. I would however get what you paid for. If it is in the contract then it should be on your home. I would suspect it is more likely a mistake than anything intentional though.
crumb is offline   Reply With Quote
Old 12-21-2011, 01:32 PM   #6
Low Slope Roofing
I don't think I've ever seen steel used instead of wood for that. Granted I do not deal with concrete tiles or see them much but I fail to see the point with metal. All of the racking is wood anyway. If the install is good it will be fine.
Old 12-26-2011, 09:10 PM   #7
chb70's Avatar
Make sure you are reimbursed for the cost difference and enjoy your new roof.
The use of the 2x4 is not a problem.
chb70 is offline   Reply With Quote
Old 12-26-2011, 09:22 PM   #8
yes talk to your contractor about this... the 2x4 should be fine ..maybe a credit is in order if that was part of the contract.....remember you don't want a patch job on a new roof....just my thougth...
Ridge cap for unlike materials Ballyhoo Roofing 0 08-31-2011 02:15 AM
Pros and cons to wood vs steel I beam framing buildings viper Building & Construction 1 05-22-2011 06:17 PM
Top Plate of a Frame Under/Along a Metal Basement Beam milwaukeemike Building & Construction 6 04-03-2011 10:04 AM
Ridge beam crowning canuck88 Roofing 4 06-30-2010 11:04 AM
New ridge beam support needed for cathedral ceiling? zachalyse Building & Construction 12 06-06-2010 08:06 PM
