Roof Within A Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-29-2013, 11:26 AM   #1
Roof within a roof
Our house used to be a one floor and they opened the original roof like slicing the top off of a cake. The original roof is still visible in the attic. Should this be left alone or could the old boards be removed leaving the frame in place?
Peter683 is offline   Reply With Quote
Old 01-29-2013, 11:55 AM   #2
Rewards Points: 243
I'd leave it unless the boards NEED to come up. It'll be a huge PITA to do.
chemman is offline   Reply With Quote
Old 01-29-2013, 11:57 AM   #3
Rewards Points: 13,266
Why would you even want to remove them?
Old 01-29-2013, 11:58 AM   #4
More for access than anything else.. will leave them in place.. thanks for the feedback.
Old 01-29-2013, 01:34 PM   #5
Doing This Way Too Long
Rewards Points: 532
You can demo as much or as little there as long as you don't mess with anything structural. What you have there is called an overbuild. If you are just talking about cutting an access into there then no problem. As stated, it's usually a messy PITA from inside the house.
OldNBroken is offline   Reply With Quote
The Following User Says Thank You to OldNBroken For This Useful Post:
Peter683 (01-30-2013)
Proper transition between shed roof and shingled roof? aribert Roofing/Siding 9 04-12-2012 04:17 PM
Tell me about roof coatings for an older roof Leica Roofing/Siding 3 09-19-2010 02:55 PM
Flat roof and insulation quandry paredown Roofing/Siding 2 08-21-2010 12:50 AM
Tying new roof into old. Clutchcargo Roofing/Siding 15 11-07-2009 06:48 PM
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 10:44 AM
