Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 08-08-2010, 04:41 PM   #1
Roof or window problem??
Hello everyone!
I live in an 1890's house that has had vinyl relplacements windows put in within the last 10 years. I have a solid double pane window that is under a front porch that leaks rain water on the inside of the glass. During heavy rains with wind, there will be water on the blinds, casement and drapes, on the inside. There are no water streaks on the outside. This is on the first story and there is a bedroom above. Our question is, where should we be looking for the problem....on the roof line or the porch above? On the roof at the top? Is the water then running down the wall and into the window frame? Any suggestions would be helpful and I can give more details if needed. Thank you!!!
Amy in Wisconsin
amyk13 is offline   Reply With Quote
Old 08-08-2010, 05:27 PM   #2
Moderator
kwikfishron's Avatar
Originally Posted by amyk13 View Post
Hello everyone!
Amy in Wisconsin
All of the above, the easiest way to troubleshoot a leak like that is get out there with a hose or pressure washer and start low and work your way up the wall and onto the roof.
You’ll find the leak or leaks.
Post a picture if you can standing back from the outside.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is online now   Reply With Quote
Old 08-08-2010, 06:26 PM   #3
Pro Slate Roofer
tinner666's Avatar
Odds are that the window above is leaking water into the wall. Houses are purposely built so water gets in. http://www.albertsroofing.com/Window%20Flashing.htm It then runs down to the next level where it shows up.
Frank
tinner666 is offline   Reply With Quote
The Following User Says Thank You to tinner666 For This Useful Post:
Gary in WA (08-08-2010)
Need opinion on this roof profenx Roofing 14 10-12-2010 01:56 AM
HELP.. unique problem with window casings! ZeroEffected Carpentry 11 06-09-2010 03:34 PM
Defog window recap greenmax General Discussion 4 05-07-2010 06:00 PM
Laying new roof after removal of old roof rupal Roofing 9 11-30-2009 05:00 PM
Wet roof a problem? amazer Roofing 16 10-13-2007 09:38 AM
