Roof Water Flow Problem - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-29-2009, 04:37 PM   #1
Roof water flow Problem
Hi everyone, I hope someone can answer my question here. I've got a fairly large house that had a front porch added on to it at one time. The problem is that rain seems to be flowing over my gable end. The new porch doesn't seem to be the problem but its in near the loacation. It's washing out my mulch and the siding gets very dirty but the worst thing is that the basement leaks bad here. Is there a diverter for gable ends of a roof? I mean some water is gonna go that way but this looks like it needs gutters to handle it all. I can't tell if the roof is just sloping that much to cause it.
paulssn is offline   Reply With Quote
Old 08-29-2009, 05:05 PM   #2
Do you have a picture of that area?
Old 08-29-2009, 06:09 PM   #3
A J-Channel, with the channel portion facing upwards, installed Under the shingles along the gable/rake edge would prevent that flowage off od that edge.
Ed
Ed the Roofer is offline   Reply With Quote
Old 08-29-2009, 08:57 PM   #4
Well I don't have a picture that shows that specific section. However this picture shows the front of my house. The roof water run off causing the problem is to the right of the front porch and it seems to be the heaviest near the porch. along the bushes on the right side right above the single window on the ground floor but it appears to be a problem all along that section.
Tags
roof edge , roof rake , roof repair
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Hot water faucet pipe thumps then flow slows down. DIY-Indy Plumbing 9 07-15-2009 11:09 PM
Water pressure problem bmoss1973 Plumbing 8 02-22-2009 05:08 PM
Preference for installing tub spout? dolvio Plumbing 7 02-11-2009 10:53 PM
water pressure problem rgmetro Plumbing 6 04-09-2007 03:57 PM
