Roof Waste Weight - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-01-2010, 11:15 AM   #1
Handyman
Rewards Points: 512
roof waste weight
Well I have to do my roof next week. I was up earlier measuring and discovered there are three layers (ashphalt) shingles. Needless to say, I will hire a couple of strong kids to do the removal but does anyone know what the approximate weight of the debris would be...I have to rent a dumpster. Roof sq ft is 1800
canadaclub is offline   Reply With Quote
Old 07-01-2010, 11:46 AM   #2
3 tab shingles weigh about 80 lbs per bundle, 3 bundles to a square - 10x10'
So approx 240 lbs per 100 sq ft of roof - 1 layer
So calculate the roof area, then figure out weight per layer
With felt, nails etc the weight will be a little more
Here there is a standard charge for the size dumpster which includes "x" weight
Any weight over the allowed is then an extra charge
Old 07-01-2010, 11:51 AM   #3
Handyman
Rewards Points: 512
Thanks a bunch Dave
Old 07-01-2010, 01:29 PM   #4
i just ripped two layers of a 22 square roof and paid for 8.1 tons. i also had at least one ton of other debris in there. i'd say somewhere around 3 tons per layer is a ballpark. nails, felt, moss, moisture, it's all in there. what the shingles actually are has an impact of course but if you budget 9 tons if it comes in less you're good. the only other question i ask is have you considered what kind of condition the deck is in? what you see in the attic and what's there when you rip off can be a bit different.
racebum is offline   Reply With Quote
Old 07-01-2010, 02:31 PM   #5
www.Ridgeline-Roofing.com
Is three layers acceptable code in California? I ask because that is against code here in North Carolina. We can put two layers on a house... and we do sometimes. Once a homeowner has two layers already we are required to rip both off before putting a new one on.
RidgelineRoof is offline   Reply With Quote
Need some help with roof - NO clue what to do, or how.. :( AdrianVall Roofing/Siding 7 04-22-2010 08:32 PM
Tile+Asphalt Roll Roof leaking - Opinion on what to do brookbphx Roofing/Siding 5 01-06-2009 06:51 AM
Addition and Roof Replacement lebeld Roofing/Siding 4 01-04-2009 06:11 PM
flat roof leak snikda9 Roofing/Siding 16 01-26-2006 04:25 PM
Flat Roof Replacement Quote Questions rocketmahn Roofing/Siding 1 01-02-2006 06:01 PM
