Roof Warranty - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-24-2011, 11:58 PM   #1
Roof warranty
What can void the warrantee of a shingle roof?
Gates is offline   Reply With Quote
Old 01-25-2011, 07:08 AM   #2
Residential Roofer
Slyfox's Avatar
Poor Installation:
Fasteners not properly placed/driven in.
Shingle alignment/spacing.
Poor ventilation.
Excessive foot traffic.
The best place to get such information is at the manufacturers website because there several issues that can and sometimes will void their warranty.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Old 01-25-2011, 07:10 PM   #3
RFN-4A-LVN
Roofmaster417's Avatar
What sly said,
1.Improper fastening,over driven under driven and placement.
2.Lack of fasteners too little used.
3.Improper application,Poor exposure.
4.Anything that the manufacture requires in installation specifications that are not followed by your installer.
5.The lack of ventilation doesn't necessarily void your warranty as much as it will greatly reduce and limit the liability of the manufacture.
6. In some cases to have a maximum warranty based on some materials certain roof materials are required( underlayment,water proofing (moisture Guard etc Basically all the products by a certain manufacture to reach the maximum warranty coverage.
Roofmaster417 is offline   Reply With Quote
Old 01-25-2011, 07:18 PM   #4
Ok also want to find out if it's a gable roof would it be noticeable if the roof is leaking on the inside would any residue appear on the sheet rack below ?
Old 01-25-2011, 09:39 PM   #5
RFN-4A-LVN
Yes a good indication of a leak will be on the drywall.But I have also seen leaks follow a rafter and run behind the wall and start buckling the base board.
Old 01-26-2011, 12:06 AM   #6
But was there any impression of a leak present on the ceiling
Old 01-26-2011, 11:56 AM   #7
RFN-4A-LVN
Nothing, the initial call was to replace a base board and do a small repair on a small area of hardwood flooring. I popped the base board and the drywall was black with mold. A typical issue if a window had been present but no window.I thought possibly it was the family pooch marking his area, but the coloration of urine and water moisture is different.I went into the attic and sure enough it was the roof. And oddly enough it followed a truss right down the wall to the floor.Since the mold was an issue,the customer wanted the area that the water was running down removed.So what started out as a small base board and hardwood repair resulted in The wall,insulation coming down and replaced along with a bigger area of the flooring since the sub floor and underlayment was rotted.
Old 01-26-2011, 12:00 PM   #8
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Not following the directions printed on every bundle.
I remember when the craze was not to install tarpaper.
The roofs didn't leak but if there WAS a problem, not installing the tarpaper voided the warranty because it was printed right on the bundle of shingles.
tcleve4911 is offline   Reply With Quote
Old 01-26-2011, 12:04 PM   #9
Experienced
Jackofall1's Avatar
The best way to see if a roof is leaking is to get up in the attic and look for water damage. Sometime as stated water will wick down a truss, sometimes it will drop down on the ceiling, eventually staining the ceiling drywall and if its the first case, staining the wall drywall.
Old 01-26-2011, 09:35 PM   #10
RFN-4A-LVN
More times than not staining will occur, you just get some that enjoy being elusive.
Need some help with roof - NO clue what to do, or how.. :( AdrianVall Roofing/Siding 7 04-22-2010 08:32 PM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 12:35 AM
Extend House Roof Over Back Deck Justahome Carpentry 17 04-05-2009 03:42 PM
Extend House Roof Over Back Deck Justahome Carpentry 1 04-03-2009 07:25 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
